      11-21-2014, 05:34 AM   #1
2006E85
2006E85's Avatar
Puerto Rico
Drives: 3.0si Roadster
2006 BMW Z4  [0.00]
Did this really happen?
Or did someone try and peel it off
I can't remember the last time I hit light speed.
      11-21-2014, 06:33 AM   #2
blacksquid
blacksquid's Avatar
Drives: 2011 135i Convertible
These cars are deceptively fast.
      11-21-2014, 07:49 AM   #3
chickdr
Drives: 2006 M Roadster
If you are serious, yes, this happens all the time. Weather weakens the paint and it flakes off. You can either replace the whole emblem, or put a sticker over the damaged one.
      11-21-2014, 09:49 AM   #4
Kimo
Drives: E31 E90 F25 MCS
Yes! I was P!SSED to discover on the morning of November 1st that my roundel was no longer blue and white, but solid silver, as the entire upper decal had been peeled off. I was sure it was some nitwit prank on Halloween night, but oddly, there was no sign of any attempt to pry off the full emblem - only the top colored part was gone.
The dealer had a new roundel in stock, and I replaced it - still P!SSED, but thankful that the reprobates had not used a screwdriver to pry it off, thereby wrecking the hood paint.
Later that day I noticed the full emblem part sitting under a bush in my front yard - so obviously it was not pulled as a 'trophy' - but had simply blown off. While I've now learned that this seems to be common with these E85 emblems, I've never had this issue with any other BMW I've owned - go figure.
When you replace the roundel, note that it is a different installation than the standard 'push in, with rubber grommets' configuration. This roundel emblem has two prongs that go all the way through the hood sheet metal and are then fastened from the underneath/engine compartment area with two lock-nuts - so be sure to get the lock-nuts too. The fan shroud needs to come off for access to the underside, and it is tight! I used a deep socket (10mm I think) to fasten mine down (actually, up), although I had just carefully pried the old one off from the top, because I didn't know any better. The deep socket is definitely needed to clear the prongs as the lock-nut is tightened up the shaft. They are too tight to simply be pushed up.
      11-21-2014, 11:29 AM   #5
UntzUntzUntz
UntzUntzUntz's Avatar
Drives: 21 M2 Comp
It's still a "Bavarian Motor", just doesn't "Werks"
      11-21-2014, 03:36 PM   #6
2006E85
2006E85's Avatar
Puerto Rico
2006 BMW Z4  [0.00]
I was dead serious, honesty thought some one tryied to peel it off. After reading you comment I went out and stuck my nail on it and it just comes out in chunks.
Oh well, at least it's not local vandalism, my Z does not normally sleep outside, but she did last night. So I immediately thought it was a bored neighbor.
      11-21-2014, 03:37 PM   #7
2006E85
2006E85's Avatar
Puerto Rico
2006 BMW Z4  [0.00]
Oh it "werks" it "werks" really good.
      11-21-2014, 04:23 PM   #8
abashoe
Drives: 2008 335xi
Is that an OEM roundel? I didnt think the OEM ones were a sticker.
On my Z3 MCoupe I replaced by chipped roundel with an eBay china special for $5. A few months later I went to an HPDE. On the front straight I saw something fly over my car. After my session I took a look and saw the entire sticker peeled off!
      11-21-2014, 06:37 PM   #9
papitosabe
Drives: '06 Z4 Coupe
you won't be able to find the cheapo/china standard colored roundel for the z4 85/86 hood, that IIRC is 70mm. The cheapos have about every size except ours. There is one guy that makes them for our cars and in different colors but even his aren't cheap.
      11-21-2014, 07:36 PM   #10
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
generally they will come off if (I've done it a few times now) you aim the water hose at it after washing the car. be careful. or possibly, if they come off with the hose, maybe its time to get a new one anyways
Powered by
      11-21-2014, 11:32 PM   #11
KevinC
your average JAMF
KevinC's Avatar
C'mon, this is Spartanburg. Bubba Makes Wheels.
'21 M2 Comp
'19 Golf R
