04-15-2014, 12:05 PM | #1 |
Rep 278
Need Help Today!!! Please
2006 BMW Z4M Coupe
Lowered on H&R Sport Springs Current tire 275/30/19 Need new tires have a deal today on 275/35/19 Will they rub?
Good things may come to those who wait, but only what's left by those who HUSTLE!"
-George Washington |
04-15-2014, 12:25 PM | #2 |
Rep 278
Wheels are 19x8.5 et35 Front 19x9.5 et20 Rear
04-15-2014, 01:13 PM | #3 |
Rep 1,543
What kind of tires? I had 19x10 et20 at the back with 275/30 Vred Ultra.. don't rub even on hard corner. However, I think the 275/35 might rub and too tall to match the front ...
04-15-2014, 01:16 PM | #4 | |
Rep 278
I know the 275/30/19 do not rub because it's what I have now, I need to know if the 275/35/19 will work?
04-15-2014, 01:18 PM | #5 |
Rep 1,002
So the Section Width is staying the same at 275 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall. so you are OK there.
However, a Tire Size Comparison calculation shown the 35 series is larger/taller so you might have a problem. Specification Sidewall Radius Diameter Circumference Revs/Mile Difference 275/30-19 3.2in 12.7in 25.5in 80.1in 791 0.0% 275/35-19 3.8in 13.3in 26.6in 83.5in 759 4.2% |
04-15-2014, 01:41 PM | #6 |
Rep 5,329
ill go out on a limb here I'm pretty certain an ET 20 9.5" rim with a 275/35 will rub....
my oem m3 260m 9.5" ET 23 on a semi slick 265/35 (close to 280 width) appears to be filling the fenders to the max and my car is very conservatively lowered prob around 10mm from stock MAX ( Not a fan of the lowered look)...
04-15-2014, 03:12 PM | #7 |
Rep 278
ugh... was a good deal! Thanks guys.
04-16-2014, 01:48 PM | #8 |
Wagon life
39
Rep 991
