      08-19-2012, 10:33 PM   #1
rsutoratosu
Drives: Z4 3.0i
07i N52 Spark Plug gap
I read a lot of threads on make sure you gap them, I dl a doc that says do not adjust, etc.
Whats the gap ? I can't check the gap if I can't find the info... Its like a mystery..
If anyone knows.. thanks.
-Roranji
      08-24-2012, 03:06 PM   #2
Ovaltine
floor sweeper
Drives: 2007 Z4 Coupe
If they're the Bosch (or equivalent) multi-electrode plugs, there's no need to gap them. Simply take them out of the box and install.
      08-24-2012, 03:35 PM   #3
CJW2OO4
CJW2OO4's Avatar
+1 the plugs i got were pre-gapped. Just did mine a month ago. You should be allset.
      09-04-2012, 12:07 AM   #4
TommyBoy01
Drives: 2004 3.0i
If you get the NGK iridiums they need to be gapped, I believe it's .032 The Bosch Plat +4's I think are .040, just make sure you don't drop them when installing it can change the gap...
      09-04-2012, 02:06 AM   #5
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Have you seen the Bosch Plat +4's (from post #2)? How do you get those Bosch Plat +4's to .040 gap? As previously mentioned, the 4-electrode type already comes pre-gapped and no need to gap them.
      01-19-2013, 04:48 AM   #6
TommyBoy01
Drives: 2004 3.0i
The Bosch Plat +4's come pre-gapped with .040 is what I was saying. But the recommendation for the NGK iridiums is a gap of .032 and you have to gap those yourself. The +4's would virtually impossible to gap yourself. Thus, if you were to drop one by accident and the tips hit something like oh idk.... The concrete, (because they slipped out of your worn spark plug socket) the gap could be compromised...
      01-20-2013, 12:00 AM   #7
vachss
Drives: Z4 Coupe
Read all the way through this thread http://www.zpost.com/forums/showthread.php?t=771325. The gap for the plugs on the n52 motor is 0.043 not 0.032 like on the M54's. When I checked the gap on my new PLZFR6A11S plugs they were all within .001 of 0.043 out of the box. I installed them that way in my 3.0si and everything runs fine.
      01-21-2013, 07:07 PM   #8
rsutoratosu
Drives: Z4 3.0i
yeah, no one reply last year when I asked about them but they recently posted it in the above thread.. so .043 for n52 motors.
you can't gap those bosch quad ones
-Roranji
