      01-28-2015, 06:20 AM   #1
Daniel7
Germany
Drives: BMW Z4 3.0i (M54)
Question Change DSC button behaviour (coding?)
Hi!
Is it possible to change the behaviour of the DSC button? Maybe via coding?
It is annoying that i have to push the button 3 seconds to get into the DSC off mode. Is there a way to shorten this time or change the behaviour of the button to something that is more useful?
Thank you very much!
Bye,
Daniel
      01-30-2015, 09:02 AM   #2
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
There may be a way, but it involves changing settings in the ECU. Not easily done. M3 folks have done it to their ECU's, but we have a different generation of Siemen's ECU. I think it's possible to have Sport Mode memory, always on and a couple of other settings. It would be difficult because you need the specific address and a binary to hex editor.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      01-30-2015, 05:01 PM   #3
pungo
pungo's Avatar
M-Track Mode
I enabled M-Track mode in the 20007 Z4MC. Short press the DSC button enables M-track mode which allows more sidways action before stability control kicks in as well as much more rear wheel spin before traction control kicks in. Long press of DSC, disables all traction and stability control. I recoded the MK60.C20 module similar to what is done on the M3.
      01-31-2015, 03:27 AM   #4
Daniel7
Germany
Hi,
thank you for the informations. The binary hacks would be a bit too much, i think.
In the last days i read about coding the DSC ECU on E46 M3's. Very interesting. Maybe i will read more about it and look what is available on the older DSC.
Due to the button behaviour: I think an easy fix is to put some electronics between the DSC push button and the ECU. I've already measured it and a simple logic in a micro controller would do the work. I will give it a try the next days.
Daniel
      02-08-2015, 09:23 AM   #5
Daniel7
Germany
Hey,
just for your information. I've done the microcontroller stuff.
It's based on an arduino. I cut the wire of the DSC push button and used one end as an input and the other end as an output to send signals to the DSC ecu.
Now if i push the button it sets to the next mode: DSC everything on -> DTC mode -> everything off -> DSC everything on. Every mode change with a short button push. Never pressing the button for 3 seconds again.
Second new behaviour is that it remembers the current mode. On the next engine start it sets the mode to the mode that was active at the last run.
I've implemented a setup to set the options and to set it easily to the stock behaviour. Everything with the one DSC push button.
I'm pretty happy with it. I'm a noob in electronic stuff and it's quite nice to see it working.
If someone wants to build something like that too, note that the cable from the dsc push button is on 12 volts when the button is pushed. I've used an optocoupler to make sure that the input pin of the arduino only gets 5 volts.
Thanks for listening.
Bye,
Daniel
      02-08-2015, 10:41 AM   #6
seank
enthusiast
seank's Avatar
48
What do you charge? Some might be interested.
      02-08-2015, 11:18 AM   #7
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Originally Posted by Daniel7
Hey,
Bye,
Daniel
Very nice! I was doing something similar to this (even got the Arduino to go along with it) but the project ended up on the back burner.
I plan to hook it up to the multi-function steering wheel buttons or cruise control stalk to control the DSC settings. I wanted to eventually go so far as to include some stepper motors on the Koni S/A shocks to change suspension settings with the steering wheel buttons. I've always got bigger dreams than the time to do them though
      02-08-2015, 12:45 PM   #8
Dalecan
Dalecan's Avatar
102
Drives: Aston V8VS, F85 X5M, TVR, 128i
Can someone translate that into English! Lol
      02-08-2015, 01:14 PM   #9
pungo
pungo's Avatar
Originally Posted by Daniel7 View Post
Hey,
Bye,
Daniel
Great job Daniel, I'm sure there will be a few people interested in this mod.
Simply put, the OP didn't like the 3 second holding of the DSC button, so instead, they changed it to a short press for any mode. As well the car now remembers the last mode selected the next time the car is started were as before, the car defaulted back to all nannies on when turned off. Brilliant!
      02-08-2015, 06:34 PM   #10
Dalecan
Dalecan's Avatar
102
      02-09-2015, 04:36 AM   #11
Daniel7
Germany
Hi!
Thank you for the compliments.
Thank you pungo for the good explanation.
That's a realy nice idea. But i don't have those buttons on my steering wheel.
Do you know if the buttons are simple pushbuttons that can be easily read out or are they communicating on a bus?
Daniel
      02-09-2015, 11:54 AM   #12
Incompatible
Drives: 07 AW Z4C 3.0Si
I would assume/hope this would apply to the N52 cars also?
      02-09-2015, 10:16 PM   #13
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
we think alike. There are 2 useless buttons on the multi-function steering wheel. One can be used for sport, the other for dsc
Tags
coding, dsc
