      03-12-2017, 05:22 PM   #1
TomHickory
Drives: 2007 Z4 3.0si Coupe
Smile SS Race Exhaust Install Suggestions ? Z4 2007
Hi All,
The Turner folks say I will get delivery of my new SS exhaust this week. Do you good folks have any counsel on the install of this item on a 2007 Z4 Coupe? It is a cat back switch from stock. I know not to expect any major HP or tourqe increases. Just looking for that good sports car sound! A buddie has a lift so it should be a clean mod. Any suggestions? Tom
      03-12-2017, 06:30 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
It's a straight forward replacement of the OE mufflers.
They do mount with adapters which give you the opportunity to set the length of the tip extensions.
Enjoy!
      03-13-2017, 04:48 AM   #3
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Enjoy!
This is for a Z4M, correct? I noticed OP has a 3.0si. On the M54 Z4's, the exhaust after the headers is all one piece, and most aftermarket mufflers are cut and clamp. I'm not sure about N52 cars.
Side note - On the non-M, the SS isn't really "cat-back" in the sense that the only cats are in the headers on the M54-equipped cars. N52 cars may have a set of secondary cats in the s-pipe.
As for sound, I've been very impressed with my SS setup.
      03-13-2017, 08:16 AM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks , good catch
      03-18-2017, 07:57 AM   #5
TomHickory
Thumbs up
thanks for the feed back gentlemen! The car is not a M it is the reg 3.0 Z4 2007 coupe The parts arrive Tuesday and will use your notes for the install. Have a buddy with a garage lift to make it easier. Thanks Tom
      09-07-2017, 12:17 PM   #6
mattgecko
LED Lighting Guy
mattgecko's Avatar
Drives: 2007 Z4 3.0SI Sport
2007 Z4 3.0SI  [8.00]
I installed a full Scorpion system on my SI, it was was a pretty easy install with the car on 4 jack stands.
http://www.zpost.com/forums/signaturepics/sigpic285982_1.gif
Hood LED kit / Trunk LED kit
