04-29-2015, 11:31 PM | #1 |
Proud E86M Owner
79
Rep 650
Advice on changing your License Plate Lights
Has any one had difficulty change their license plate to led? I bought a pair on eBay and I do not know if I am doing it wrong, or the fitment is not correct. The guarantee "Direct replacement with OEM quality and fitment" and I test them no error codes which is good, LED quality is much better but I cannot put them back in their place. Has any one had problem or had an advice for this?
I am afraid of breaking something. This is the ones I bought http://www.ebay.com/itm/191481688659...%3AMEBIDX%3AIT Wanna to take pics when done but it is incomplete at the moment.
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute) 2016 Honda CR-Z EX Jet Black (Daily Commute) 2008 Kawasaki ZX6R Plasma Blue (SOLD) 2008 Z4///M Roadster Space Gray (SOLD) |
04-30-2015, 08:02 AM | #2 |
Enthusiast
16
Rep 245
I believe I bought the same set - zero issues installing - plug and replace. Snap right into place.
2016 550i M-Sport
2008 328i M-Sport (Sold) 2007 Z4M Roadster (Sold) |
04-30-2015, 09:28 AM | #3 |
Rep 10,597
I bought the exact same ones as well, the light looks incredible at night and REALLY refreshes the back of the car. Makes it look a newer model without the nasty yellow lights. Mine snapped right into place with no problem and have been there and working great since last July. Good luck.
04-30-2015, 11:34 AM | #5 |
Rep 994
I have WeissLicht LED light and didn't have problems with fitment but i think i did bend the tab a little to get it fit more snugly. So i think it is OK to trimmed a bit off if need to get it fit.
This is one of those mod that we will never get to see while driving the car |
04-30-2015, 12:44 PM | #6 | |
Rep 72
Drives: 2008 E86 Z4 MC
Looks like you received a complete assembly which might not be the same sixe as the stock one. |
05-01-2015, 11:47 AM | #7 |
Rep 904
Do you have to wear clean nitrile gloves when handling LED lights like you do with halogens to prevent skin oil from contacting the bulb?
05-01-2015, 12:23 PM | #8 |
Rep 217
Shouldn't have to. Obviously don't slobber over them but they're fairly bullet proof. The reason you do gloves with Halogens is they are so hot and anything on the glass becomes the failure point as it concentrates the heat.
05-01-2015, 12:51 PM | #9 |
Rep 1,031
The stock E89 led license plate lights fit and work. There is a tiny little tab inside the plug area that you need to chip out and they fit and work. Cost me $20.75 each.
Part # 63-26-7-193-294
05-01-2015, 12:55 PM | #10 |
635
Rep 3,124
^WHS
Definitely not. LEDs barely heat up at all, and the lenses are soft plastic, not brittle quartz. Contamination on the quartz concentrates the heat which makes the contaminated part of the glass expand more than the glass around it, which causes internal stress and can crack the glass.
05-01-2015, 02:53 PM | #11 |
Proud E86M Owner
79
Rep 650
I got such a hard time figuring out. It was not an easy plug and done but the trimmig suggestion help out. Thank you for the advice. Will take pic later.
Who ever point the results are great are correct. Who ever said its a upgrade we will never see, is true but gets more people to turn and look at ur plate xD |
05-01-2015, 04:00 PM | #12 | |
Rep 321
05-01-2015, 04:14 PM | #13 | |
Rep 2,846
05-01-2015, 04:30 PM | #14 |
Rep 1,060
Yes, installed OEM 1 series lights in my car. Similar to the E89 lights mentioned above, you need to dremel out one small plastic tab and then you can install exactly like oem incandescent housing.
05-02-2015, 02:24 PM | #16 |
Proud E86M Owner
79
Rep 650
01-18-2016, 04:23 AM | #18 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
While it looks cleaner, the last place I want any extra light is my license plate
01-18-2016, 08:37 AM | #19 |
Rep 1,987
If you want the look without the cost, buy blue coated halogen bulbs. Looks white, but no so bright. That is what I did. Or buy T94 wedge LED bulbs to replace the stock filament bulbs in the OEM housings.
01-18-2016, 10:19 AM | #20 | |
Rep 2,527
