08-31-2023, 07:14 PM | #1 |
Rep 40
Another Header Thread
I have a 2005 Z4 with FI from Vortech. Exhaust is stock and so I am looking to replace the headers to improve flow and HP. I think I have settled on buying these from racing dynamics. Because this is a street car, I will need to pair these headers with some high flow cats. Anyone have recommendations they have had success with? https://www.racdyn-usa.com/PROD/130+08+54+365.html
08-31-2023, 07:34 PM | #2 | |
Rep 566
08-31-2023, 07:53 PM | #3 |
Rep 40
Thanks. So did you replace the cats or just delete them? I am thinking I will need to pair the headers with some high flow cats but want to ensure I have something that will definitely fit.
08-31-2023, 08:00 PM | #4 |
Rep 566
In the pic the first section that attaches to the headers is the cat section from supersprint, they make both straight pipe section or with their cats. Unless you code out the post O2s you’d have to go with something of this route if going with catless headers if there’s emissions where you’re at that might be an issue coding them out or dealing with a cel. No codes thrown with plugging in the O2s in the supersprint catted section.
08-31-2023, 08:20 PM | #5 | |
Rep 40
09-01-2023, 08:12 AM | #6 |
Rep 40
Found these: https://privatelabelmfg.com/collecti...tic-converters
Might give them a shot with the racing dynamics headers and a magnaflow muffler. |
09-01-2023, 10:50 AM | #7 |
Rep 2,706
You will want to consider metallic cats over ceramic, being FI.
Don't know what the internals are on the cats you posted.
09-01-2023, 11:03 AM | #8 |
Rep 40
Thanks Steeler. Any other recommendations you might have for high flow CATS that won't break the bank? Still putting kids through college
Also, off topic, but what did you use for your intercooler? |
09-01-2023, 11:49 AM | #9 |
Rep 2,706
Take a look around this site.
https://www.siliconeintakes.com/fron...t-intercooler/ I ended up with magnaflow section 2 meant for an N52 I believe (bit of fab work required to rotate flanges at the header collectors) and magnaflow metallic cats in the end and 3" supersprint system back from there. I learned the hard way about ceramic cats with FI
DiscoJax7.50 |
09-02-2023, 10:22 AM | #11 |
Rep 40
I'm researching these but will probably hold off for a bit. Between the new tune, probably a bad throwout bearing and now headers, I think I have spent enough.
I did place the order for the Racing Dynamics headers. Those guys were great to work with. They emailed me back and forth immediately, answering all my questions and then shipped them right out. Should be here tomorrow and I am going to see if I can get installed on Tuesday and then finish the tune. For now I will go catless. I may add CATs in the location of the small muffler later on when I get the muffler done but, one thing at a time. |
Piper1571.00 |
09-02-2023, 11:28 AM | #12 | |
Rep 566
DiscoJax7.50 |
09-02-2023, 03:00 PM | #13 |
Rep 2,706
WA intercooler packaging is tight for our platform. But is doable.
DiscoJax7.50 |
09-03-2023, 04:57 PM | #14 |
Rep 40
Very nice! Just got these today. Quick shipment from Virginia!
09-30-2023, 04:49 PM | #15 |
Rep 40
Got the headers in and new tune with the RS4 MAF. With the Vorterch supercharger, I've realized some nice power gains and it sounds great when I open up! Still working through a rich warm idle with the tuner.
Still have the stock exhaust. I will likely not swap that out until sometime next year. No real need though because it really sounds nice as is. The Racing Dynamics headers are really nice and well designed. I typically do my own work but I splurged and had an Indie shop install them. They were were pretty impressed with the support and the relative ease of install. One problem I did have was that one of the headers tended to be 1/4 in shorter than expected. Racing Dynamics sent me a full new set to make up for the problem but we fixed it just by adding a spacer. So I have an additional NIB set. PM me if you are interested. I'll upload some a video soon with the sound. |
