      07-17-2007, 11:48 PM   #1
angelsz4
silver bullet
angelsz4's Avatar
Drives: bmw z4 silver bullet
will these rims fit ??????
help me out guys.... i really hate doing research i wanna know if these rims are ok for a 2004 2.5i... 19 x 8.5(Front) +19x9.5(Rear)
245/35/19(Front) + 275/30/19(Rear)..... and if not, what can i do to get them to fit?
here are the rims just in case you wanted to see them
http://www.wheelsnext.com/default.cf...lor=HYPERBLACK
      07-18-2007, 12:11 AM   #2
OH FO SHO
OH FO SHO's Avatar
15
Drives: z4
it looks like they will fit according to the filter on the page, but it also depends on the offset.
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers
-*MY PICTURE THREAD*-
      07-18-2007, 01:38 PM   #3
mister_roger
mister_roger's Avatar
13
Drives: 2003 Maldives Blue 2.5i
It definitely would depend on the offsets. An offset between 35 - 40 for both front and rear sounds about right. But regardless, those seem like pretty aggressive tire widths, and may cause rubbing if you plan on lowering your car. It looks like your car is just a standard 2.5i withough sport suspension, so rubbing may not be an issue, but I would probably go 235/25/19 front and 265/30/19 rear just to be on the safer side.
2003 Maldives Blue 2.5i -- 18" M6 wheels, 12mm rear spacer, ///MZ4 front bumper conversion, Eibach lowering springs, Koni shocks, Hotchkis F/R anti-roll bars, Helene Performance air filter.
      07-18-2007, 02:54 PM   #4
GP20
Drives: Z4M, F80 M3, 991.2 GTS
Roger, you mean 235/35/19 for the front?
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      07-18-2007, 05:05 PM   #5
mister_roger
13
Whoops, my bad
Yeah, 235/35
      07-18-2007, 07:52 PM   #6
angelsz4
silver bullet
angelsz4's Avatar
ok so i went to discount tire and they said the biggest i could go is 225/35/19
275/30/19.... yes my car is 2.5i not sport... and i dont plan to drop it ... so what do you all think then
      07-18-2007, 08:19 PM   #7
GP20
225/35/19 & 275/30/19?
Go with 235/35/19 & 265/30/19 like mister_roger said.
2016 BMW M3
2008 BMW Z4M coupe
      09-20-2007, 06:43 PM   #8
rlc
rlc's Avatar
34
Drives: '06 E90 - '04 E85 - '16 F15d
2016 BMW X5 35d  [0.00]
2006 330i  [0.00]
2004 Z4 2.5i Roadster  [9.00]
Upsizing wheels/tires - Height adjust necessary?
Is the Sport Z4 roadster lowered (like my Sport E90) and if so how much lower than the non-sport?
Reason I ask is when/if I upsize the wheels/tires will they look strange if nothing is changed with the non-sport suspension? As far as I can tell the lower sidewall heights on the larger tires on 17" or 18" rims doesn't change the overall diameter much more than an inch or so. Have I got that right?
      10-01-2007, 06:29 PM   #9
Waldorf
Black Opps field agent
Waldorf's Avatar
Drives: 135i M
Here's a handy wheels spec calculator to help you figure our the effect of width and offset.
The original values are those of the Z4 M Coupe so you will have to change them to those of a standard Z4 and then play with the values in blue to compare with aftermarket offerings.
http://desmoclan.org/images/tmp/whee...calculator.xls
:rocks: Montreal to Vermont OktoberFast cruise. :rocks:
http://www.e90post.com/forums/showthread.php?t=79557
Search this Thread:
Advanced Search
