      03-08-2014, 09:12 AM   #23
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Originally Posted by RobMCoupe View Post
I bought an older laptop with real serial port and cable with ADS interface. If EDIABAS have ADS interface support it should work. The problem with this bundle setup is it is not a full version so it does not have ADS support. Look in C:\EDIABAS folder hardware folder is missing. It should be simple to switch between OBD and EDIABAS by changing EDIABAS.INI from interface = ADS. I have it setup to use ADS/ODB.
As I recall, it said E36 support. That is probably true but have limited access via OBD. I'm not knocking the seller. He instantly offer me a refund. It's just an FYI for those thinking this have ADS support.
Soo what should I buy then?
      03-08-2014, 12:38 PM   #24
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
bmwmotoon will do if you don't need ADS.
I personally like to have one tool to scan older models. You never know if you need it in the future. In my case, I have 94 325is which require ADS interface.
      03-08-2014, 08:27 PM   #25
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
Originally Posted by Taylorguy74 View Post
Cruising along in fifth gear, lightly pressing the gas, hesitates as above, throws the lights and drops to idle - I turn off and restart while still rolling, and it runs fine.
If that happened to me in 5th gear (probably doing 60mph) it would absolutely scare the shit out of me.
