04-24-2019, 12:27 PM | #1 |
Get Some
226
Rep 759
Drives: 07 Z4 3.0si
Oil pan gasket
Just started leaking are there any other gaskets I should replace wall the oil pan is off...If anybody knows of hand real quick I'd appreciate it
04-24-2019, 12:49 PM | #2 |
Get Some
226
Rep 759
Drives: 07 Z4 3.0si
N52 3.0 btw
04-25-2019, 06:59 PM | #3 |
Get Some
226
Rep 759
Drives: 07 Z4 3.0si
Anyone?
04-26-2019, 12:05 AM | #4 |
Rep 384
I don't know of any while the oil pan is off, But while your at it i'd recommend the two gaskets on the oil filter, heat exchange housing. Its sort of easy to reach and only about 60 bucks, should be changed around 75-100k miles.
http://www.realoem.com/bmw/enUS/show...diagId=11_3753
The Internet said it. I believe it. That settles it!
04-26-2019, 01:25 AM | #5 | |
Get Some
226
Rep 759
Drives: 07 Z4 3.0si
04-27-2019, 03:22 PM | #6 |
Rep 18,785
I have a 2006 E90 with an N52 in it with 370,000 miles so I know the N52 pretty well. If you've done the top side gaskets: oil filter housing, and valve cover, then really all that is left is the oil pan gasket. Now don't let it trick you into thinking the rear crank seal is leaking. The rear of the oil pan intrudes into the bellhousing behind the flywheel. The N52 pan usually starts to leak in the right rear corner. That where it is first visible at least, but it will also leak at the rear lip of the pan inside the bellhousing and make it look like the rear crank seal is leaking.
I replaced my oil pan gasket on my E90 as a DIY and I've replaced the clutch also. I did the clutch first and bought a rear crank seal thinking the seal was leaking. When I pulled the trans out, and removed the flywheel, the rear crank seal was dry as a bone, and still is at 370,000. The leaking rear of the oil pan made such a mess in the bellhousing, I repaired the oil pan gasket within the next few weeks. If you are going to DIY the oil pan, the E90 DIY section has a great DIY on the oil pan gasket. The procedure requires the front subframe to be dropped, the newtis.com site has the repair instructions to drop the front subframe. My advice is use gasket sealer on both sides of the new gasket. I used Permatex Ultra Black. It's been leak free for 3 years and 80,000 miles.
WickedNy226.00 |
04-28-2019, 06:46 AM | #7 | |
Get Some
226
Rep 759
Drives: 07 Z4 3.0si
04-28-2019, 09:00 AM | #8 | |
Rep 18,785
