11-13-2012, 02:14 PM | #1 |
703
Rep 7,850
Wheel Fitment Database/Summary/Grid
We have the wheel fitment thread sticky, but there's no easy way to find all the options out there (and results) without reading through it (painful).
Here is a Google Doc that Flyzipper shared with me. I've modified it a little bit so that we can try both M and non-M fitments. Please feel free to add your information to the list. Here is the link. Last edited by Finnegan; 03-24-2013 at 06:03 PM.. |
12-11-2012, 09:10 PM | #2 |
Rep 51
Would be very useful I find myself in this boat now as I try to dig around for specs to see if Breyton makes a Race GTS in an 18/19" that fit the Z4
12-11-2012, 09:35 PM | #3 |
#dubspec
6336
Rep 5,201
you need a 8.5et35 front and 9.5et38 rear. will fit the z4 non m flush
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
12-12-2012, 12:37 PM | #6 |
Rep 924
There already is a google doc someone put together but I can't find it. Perhaps you can use it/tweak it without starting from scratch.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts '09 X5 35d — Space Grey / Saddle Brown 20" Forgestar F14 / SCR Delete |
12-12-2012, 01:59 PM | #8 |
Rep 924
It must be somewhere in the Definitive Wheels Spec thread. It's pretty detailed.
12-13-2012, 11:42 AM | #10 |
Rep 12,565
Spreadsheet via Google Docs, that way you can add filters for m vs non-m, diameter, width, etc
OR just create a spreadsheet with a calculator built-in. It won't be 100% absolutely correct (tire width will vary by make) but at least for stock suspension it should be close enough. If someone gives me baseline clearances on strut & fender sides, I can create a spreadsheet that will do the rest. Last edited by 3002 tii; 12-13-2012 at 11:50 AM.. |
12-21-2012, 06:28 PM | #12 |
703
Rep 7,850
Spreadsheet already exists as Aestheticstorm noted.
I cannot be edited however, and we'd need to add a few more data elements. the good thing is that it's a really great start, and has data already. I've PM'd the spreadsheet owner regarding using their spreadsheet, or using their data for a new one. I've asked that it be opened to editing (like the battery summary spreadsheet), since allowing folks to add their own data (if they have the right link) is just easier than trying to maintain it. Once I hear back, and we have a plan, we'll move to sticky the thread with the existing spreadsheet or this thread, and then open it for data entry/viewing. |
12-22-2012, 08:54 AM | #13 |
Rep 12,565
Worst case just start a new one, wouldn't take very long to populate...
12-31-2012, 08:03 PM | #15 |
Rep 415
Drives: 2005 z4 3.0
good work, looking forward to it, looking for new wheels for the summer
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | custom speedo logos | stubby antenna | polished exhaust tips |
03-18-2013, 10:37 AM | #17 | |
The Wrapgician
47
Rep 354
Drives: z4si
03-18-2013, 11:28 AM | #18 |
Rep 347
Drives: 2006 BMW M COUPE
I am no expert but the R +45 may be out too far ? Most used here in 9'5 are 22 or around there ? Gee those wheels are not cheap are they ?
is this the spreadsheet you were referring to > https://docs.google.com/spreadsheet/...WeUg1b2c#gid=0
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
03-18-2013, 01:10 PM | #19 | |
The Wrapgician
47
Rep 354
Drives: z4si
isnt the +smaller number will be outer? mine OEM is like +50 and people doing +35~+40 to make it flash? confused yes... they are not cheap and all custom made and shipped from Taiwan... so i dont really wanna screw up at any point... |
03-18-2013, 01:17 PM | #20 |
Rep 347
Mine is an M coupe so sorry if I confused you :\\
Here is a link you can plug in different offsets and see what it does. http://www.1010tires.com/Tools/Wheel-Offset-Calculator
03-19-2013, 12:41 PM | #21 |
The Wrapgician
47
Rep 354
Drives: z4si
so I did this check, is inner clearance 14mm less mean like it will appear like i put on a 14mm spacer on my OEM wheels? whats outer position means? |
03-19-2013, 01:33 PM | #22 | |
Rep 441
the 14mm less inner clearance means it will be 14mm's closer to the shock |
