      03-25-2010, 06:25 PM   #45
VitaminT
Drives: 2006 M Roadster
After I got used to the car I haven't had it happen but that may be because I tend to wait a split second after letting off at 8k to pull the shifter to second. In my case it almost sounded like the selector made it past the syncro but didn't engage with the actual gear. It was a high pitch grind.
      03-25-2010, 06:53 PM   #46
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
have to admit, the synchros have a job... and smooth shifting has rewards.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      03-28-2010, 07:49 PM   #47
just2talented
just2talented's Avatar
Drives: Alpine ///M roadster
I've also noticed that. Once your at redline in first, clutch to the floor, if wait the extra half a second and then slam 2nd. It won't do it. However it needs to be said that our 50-60k$ sports cars shouldn't have this problem whatsoever. I feel this is a synchro issue. I've had syncrho issues in other cars and this problem is very similar. Going to do an amsoil tranny fluid swap. Amsoil syncrho mesh fluid.
      04-05-2010, 05:05 AM   #48
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
Originally Posted by MVF4Rrider View Post
Before I departed Germany in early June of this year, I inquired about the grind and was told it's all shifting technique. They told me to hold the gear shift with firm pressure to the left as you pull the lever into 2nd (keep the left pressure all the way through the shift). I haven't had a grind since and I can shift at high rpms at will. CDV has nothing to do with it.
I can confirm that MVF4Rrider's technique WORKS (Firm pressure to the left all the way through the shift).
By making this minor change to your driving style, when you want to you can now shift at the redline with confidence.
Thank you for sharing this secret.
      04-05-2010, 12:31 PM   #49
RichardTS
RichardTS's Avatar
Drives: 335i E92 & Z4 M
I might buy that (in hope--which is far from fact) had I just not spent the last 5 years in Germany. Over there, when techs need answers to questions or concerns they don't shoot from the hip, they call Munich and get the right answers direct from the source. My car is at 7,000 miles and it was broken in following the BMW guidelines to the letter. It would grind now if I don't use the method conveyed to me. But I guess at 10,000 miles it will magically correct itself? Doubt it. Ultimately I don't abuse it and the few times I experienced the grind I wasn't revving it into oblivion.
Mine now has about 19K and it is better than it was at 10K. What they told you in Germany is exactly correct and I hope everybody is doing this when they shift. If you were going to tell someone else where 2nd is, wouldn't you say "back and toward the driver?" If you think this while driving you will be doing it correctly. Mine would probably go to 4th if I didn't keep the pressure to the left on it.
I think you may have the definitive answer and this is probably why some people don't have a problem and others do.
      04-10-2010, 01:25 AM   #50
Thisisdudewhoru
Thisisdudewhoru's Avatar
Drives: 16 BSM 340i
In my old car(07 civic si, yea I know, no comparison) everyone was getting 1-2 shift problems at high rpms(we have same 8k rev limit). Ours was due to the mounts being too soft and it moving the motor and tranny enough to cause slack in linkages and mess up the shifts. Also on our cars if it mounts were not replaced or a engine torque dampner wasn't installed, after grind after grind happened, irreversible damage was done to the trannies and they had to be replaced for the problem to go away.
But I'm currently waiting on my M to arrive with 14k miles on the clock and I'll give some feedback soon.
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
      04-10-2010, 07:28 AM   #51
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
Maybe we should do a group buy for new tranny mounts.
Rouge Engineering has them for like $55
http://www.rogueengineering.com/Merc...tegory_Code=TM
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      04-10-2010, 07:40 AM   #52
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
If it would help with the occasional grind then i'd be interested in a group buy (if shipping them out here isnt horrendously expensive of course).
      04-10-2010, 07:55 AM   #53
The__J__Factor
Australia
88
Drives: ///M Coupe
Depends if its a problem with tranny movement causing the grind then the stiffer mounts could help a lot.
If its a syncro issue it might not help as much.
Dont think shipping would be too much since its a relatively small package.
135i N54 manual
      04-10-2010, 10:23 AM   #54
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I have some on order from LeatherZ and will have them installed week after next; my local Indie shop did mention the black mounts over the urethane, I guess the noise and vibration in the Z is more pronounced than other BMWs.
      04-10-2010, 10:26 AM   #55
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I agree, but the transmission is so inconsistent and I would think a syncro issue would cause the issue each and every time. For instance, on my daily commute, I have to make a hard left onto a rotary and uphill, so I hit the left hard and apply power, the 1->2 is butter smooth. It seems when I'm tossing the car left hard, the shift is sweet, so I suspected the tranny or engine movement. This issue is also worse as the warm weather approaches ... rubber gets softer and more pliable in the heat???
Figured I'd start with the tranny as it's inexpensive to try regardless and BMW tranny mounts aren't known to be the best.
      04-18-2010, 08:12 PM   #56
G80indy
Save the Manuals
G80indy's Avatar
Have you guys with the grinding 2nd gear issue had the motor mount bolts addressed?
I wonder if there's a connection?
2023 G80 6MT, CCBs
      04-18-2010, 10:49 PM   #57
Thisisdudewhoru
Drives: 16 BSM 340i
Well, I got my car friday. So far, no grinds.
      04-19-2010, 09:32 AM   #58
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I've had mine checked repeatedly at Indie and dealership visits, I guess I have the ones made after the SIB was produced (Aug/2008), and hence the reason I'm changing the transmission mount bushings this week or early next week, probably nothing to do with the lack of smoothness (I have no grinding/crunching), but rather to do with the inconsistency with which it shifts.
      04-19-2010, 12:12 PM   #59
G80indy
Save the Manuals
G80indy's Avatar
I took my M-R out yesterday to heat it up with revs and engine braking. The shifts were silky. as 1-2-3 were equally slick with downshifts included.
I was really looking for the symptom, but it just wasn't an issue for me.
2023 G80 6MT, CCBs
      04-22-2010, 12:21 PM   #60
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Had the Rogue transmissions mounts installed today; techs took one look and compared the ones removed and the new ones were: "nice, beefy". I find the shifting is improved and especially when braking and moving the lever, especially the 3->2 where I've been denied a couple of times. That is now gone. This isn't a cure for the notchiness, but it is shifting consistent now. The original bushings were the typical BMW hourglass rubber, you could compress the rubber with your fingers whereas the Rogue mounts are still neoprene rubber, they are far stiffer and should last much longer.
      04-22-2010, 01:35 PM   #61
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ good to know.
Do you have an SSK installed as well?
      04-22-2010, 01:53 PM   #62
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
^ good to know.
No, the car doesn't need any type of ssk as far as I'm concerned; at least for me, the throws are nice and firm. The Whalen helps a lot with the nice firm shifts.
      04-22-2010, 02:02 PM   #63
vasaline
Drives: 06 M Roadster
This grind that everyone is talking about, is it actual noise that u hear from tranny or a grinding feel on the shifter when u shift?
      04-22-2010, 02:06 PM   #64
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I agree that it doesn't need to be shorter.
I just wondered if the improved pivot bushings & mechanicals would gain similar improvements as the changing tranny bushings.
      04-22-2010, 02:08 PM   #65
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Both.
Plus rejection of 3-2 downshifts.
You will know when/if it happens.
I've been lucky so far myself.
      04-22-2010, 02:14 PM   #66
vasaline
What I am experiencing is the grinding feel on the shifter. Only way for me to not have that is to shift slower. Is there any other tehnique that I can use to prevent this grind besides shifting slower as it is kind of defeats the purpose of driving a high performance sports car.
