      10-26-2010, 08:48 PM   #67
jbh
jbh's Avatar
18
Drives: 2007 Z4M
Originally Posted by dekaliber View Post
jbh what did your camber/toe settings end up being? I thought I saw it in a post elsewhere but I can't find it now.
-2 up front
-1.5 in rear
0 toe up front
3.32 toe in back
      01-14-2012, 09:53 AM   #68
SmartBastard
Stupid as shit
SmartBastard's Avatar
Austria
23
Drives: '08 M Coupe
Is there a way to get the that kit over here in EU? Would feel bad about $40 shipping cost for something that costs $15 in first place. I might try a hardware shop, I have no idea what the metrics you guys posted exactly mean and if the hardware shop will be able to find out (gonna have to try I guess).
      01-14-2012, 10:13 AM   #69
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
you can simply make your own kit from a specialty bolt store, here were my specs....
10.9 grade, m12, 1.75, 30mm
2.5 x 8 washers (you won't need all of them)
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      01-14-2012, 10:54 AM   #70
SmartBastard
Stupid as shit
Austria
23
Drives: '08 M Coupe
Cheers, I'll give it a try.
      01-14-2012, 12:27 PM   #71
Shipkiller
Shipkiller's Avatar
Drives: Me
Whether you buy a kit or source your own, be sure to measure each washer and group them so each set is approx. the same thickness.
This will ensure you have approx. the same setup offset for each set, both fore and aft sets and on each wheel.
      01-14-2012, 01:28 PM   #72
BIMMERGUY91
Drives: 2014 335I M Sport
Im running -1.7 front and about the same in the rear for daily driving and I really like the added bite it gives
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      01-14-2012, 05:13 PM   #73
beta
Drives: 2006 M Roadster
FYI if you're going to get coilovers at any point don't bother. With the drop from the coilovers I got less than -2 in the front without having to do anything (and this is at max height).
      03-27-2013, 04:58 PM   #74
S2000
Drives: E86 Z4M, E60 M5, E92 M3
With KW Clubsport lower ride height and maximum camber setting , I am getting camber:
-3.5 front
-2.5 rear
I use that setting for daily driving and so far (35k street miles) have not experience significant un-even street tire wear.
After a couple years of track events and moving into instructing and time trials, the front tires are still wearing significantly more on the outside so I am trying this kit
http://www.turnermotorsport.com/p-42...otorsport.aspx
Just want to share that one washer adds about 0.5 camber.
With two washers, I am now running at -4.5 front.
Will report by May on tire wear and handling characteristic.
      04-08-2017, 02:00 PM   #75
Jackal
Jackal's Avatar
Drives: 2006 Z4MC (Bianca)
Setting about this job today. I have all the hardware, but i can't find the torque specs for the bolts. Any input on that?
EDIT:
Looks like I found it.
Torque spec for all 3 bolts is 81 Nm or ~60 ft-lbs.
http://www.zpost.com/forums/showthread.php?t=441043
Light a man a fire, you keep him warm for a night. Light a man ON fire,you keep him warm the rest of his life.
      12-31-2017, 01:41 PM   #76
Extremex
Drives: Z4 3.0 SI Roadster
Do you know why this kit can't be mounted on a Z4 E86 non-M ?
      12-31-2017, 08:26 PM   #77
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
The Z4M has a 3 bolt design for the strut attachment to the spindle casting, same as the E36M3. The non-M Z4s have a socket/clamp type mount same as the E46 so there's no means to alter the geometry with spacers.
Non-M strut attachment to spindle casting:
http://bmwfans.info/parts-catalog/E8...hock_absorber/
Top Down 365
      01-01-2018, 03:45 AM   #78
Extremex
Thank you very much, that's clear...
I have to find another solution to add camber to my 3.0 si then...
I heard about a solution with Z3M front top shock mount... it would be possible to mount the right one on left side, and left on right side... it's possible on Z3 and E36, but I don't manage to find if it is ok for Z4 too...
      01-01-2018, 10:42 AM   #79
dc_wright
dc_wright's Avatar
249
I haven't looked at shock mount swaps for mine so can't offer any input on that mod. It's not an allowed mod for SCCA Street class autocross, so all I've done so far is remove the strut bearing positioning pins and maxed out camber as much as the slotted holes in the strut towers would allow. It gives approximately 0.8 to 1.0 degree add camber and it's "free".
Top Down 365
      01-01-2018, 12:10 PM   #80
Extremex
i'll do the same mod I think
      02-06-2018, 09:36 PM   #81
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Thats because the oem shock mounts (front) for the Z4 M and non M are symmetrical. the Z3m ones are not. Currently running swapped Z3M hats in my 3.0i Z3 WITH the camber washers. Gives quite a bit of negative camber lol.
Powered by
