      08-01-2022, 07:43 PM   #1
Brendon12343
Drives: BMW Z4 3.0SI
Passing Emissions with ESS Supercharger kit G1
My emissions are due and have to get the car to somewhat of a stock setting. So far I have the stock injectors, stock tune, and the yellow wire to the maf sensor soldered. However, my SES comes on with error code p1424 saying air flow is too high. Is this due to the supercharger blowing too much air even at idle? The pipes seem to be good and clamped tight, breather hoses are not loose etc. Folks at ESS actually took in my vehicle and verified install. This was two months ago.
Once the maf does its "check" on engine start, the rpm kind of searches just above 500. After 20 seconds the SES comes on and the car idles and drives fine. Though if I were to drive before those 20 seconds the car kind of hesitates below 2k rpm.
I swapped out the maf thinking it was dirty or worn but the problem persists. Should I also swap back to my stock belt without the supercharger pulley connected? Just would like to know those who are also running this kit, how they pass emissions?
      08-02-2022, 01:41 PM   #2
Phatty
Phatty's Avatar
11
Drives: Bmw E86
you will need to remove the supercharger. return everything to stock or stock like or it wont even pass visual, here in california at least.
if it were not for the kit being non carb legal for the n52, i would have got the kit.
      08-02-2022, 03:22 PM   #3
Brendon12343
Here in AZ they don't do visual checks fortunately. Just monitor readiness. I'll give the stock NA belt a go to see if the error goes away.
      08-02-2022, 05:16 PM   #4
Phatty
Phatty's Avatar
11
Drives: Bmw E86
you would still want to remove it, good chance its running lean, i dont think the ecu can compensate for positive pressure in the intake.
      08-02-2022, 06:17 PM   #5
Steeler
Steeler's Avatar
2429
Why don't you get the ECU tuned correctly so emissions are never an issue?
      08-02-2022, 11:58 PM   #6
Brendon12343
Yeah new codes popped up P0175 and P0172. Going to have to throw cold air intake in.
      08-03-2022, 12:04 AM   #7
Brendon12343
The tune provided by AJ from ESS does not have emission readiness or something to that effect. I've emailed him back and forth regarding emissions but he's never mentioned an emission friendly tune.
      08-03-2022, 05:56 AM   #8
Steeler
Steeler's Avatar
2429
Check my sig below for the guy to contact for tuning.
AJ is good at what he does but tuning is not ESS strength IMO.
      08-07-2022, 01:47 PM   #9
wyshyvanuk
Drives: 2008 Z4 MR
+1 for Severn Tuning.
      08-08-2022, 02:34 PM   #10
tikamak
Lebanon
58
What is it that he does that he's so good at ?
      08-08-2022, 02:37 PM   #11
Steeler
Steeler's Avatar
2429
Who are you talking about?
      08-15-2022, 12:03 AM   #12
WeekendWarriorz
WeekendWarriorz's Avatar
670
Drives: 2006 Z4M
@pokeybritches
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
