      06-02-2011, 09:54 AM   #1
hilaloruc
Drives: 2007 BMW Z4 3.0i
can i put 07 z4 engine into 04 z4?
hello everyone,
I have 2007 z4 3.0 i (US) engine and auto transmission, has 30k miles. I found a 2004 Z4 3.0 (US) with no engine and (auto) transmission. I was wondering, If I get this car , is it really hard to put the engine in, or is it impossible?
what are the differences between them?
thank you
      06-03-2011, 12:53 AM   #2
Arxangel
Arxangel's Avatar
Bulgaria
16
Drives: 2006 Z4 3.0si Coupe
2006 Z4 3.0si  [8.50]
Well the cars appear to be the same except for the production year. Why would you want to move the engine from a newer model to an older model that is exactly the same and the first one? Don't get me wrong, I am all for engine swaps and the likes, but this just seems... weird!!
And to answer your question, it will probably fit, you have to move the ECU as well because there might be differences in the programming. The gearbox should be the same.
      06-03-2011, 08:34 AM   #3
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
Yeah... what's the point of switching to the older body?
      06-03-2011, 10:02 AM   #4
FerRrari
FerRrari's Avatar
19
Drives: Catrinel Menghia
I believe what the OP is saying is.
- He has an engine and a transmission from an '07 car (I'm assuming the car is wrecked/parted out).
- He found an '04 car without an engine or transmission.
Adding the 2 together will get the OP a working car.
'12 Nero/Rosso 500 Abarth
'07 IR/SBL ///M Roadster (GONE), '08 Tornado Red Triumph Daytona (GONE), '09 BRG/Cloth 6MT MINI Cooper S (Spontaneously Combusted), '06 IR/IR ///M3 Convertible 6MT (GONE), '04 JB/CR Z4 2.5i SMG (GONE)
      06-03-2011, 10:10 AM   #5
arggg45
No_Country
11
Drives: fairly quickly.
didn't they change the ECU Pinout after the facelift?
If so, you'd have to transfer the whole wiring harness, etc.
If not, I'm delusional.
"It will not have enough power until I can spin the wheels at the end of a long straight in top gear."
-Mark Donohue
      06-03-2011, 10:36 AM   #6
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
There are probably more changes between an 04 3.0i and an 07 3.0si then there are to a 07 3.0si and a 07 Z4 M
This is something I would only attempt if I was building some kind of race car, the effort involved doesn't seem worth it.
      06-03-2011, 11:37 AM   #7
hilaloruc
... I'm parting out wracked 07 Z4... I found this 2004 Z4 with no engine and transmission.... And its salvage....
like you guys said , it's not gonna worth it... I m not gonna do it.. So if anyone needs really clean engine and trans. Let me know
Thank you all
      06-03-2011, 12:12 PM   #8
Arxangel
Arxangel's Avatar
Bulgaria
16
Thank you all
If you have all of the other electronics and harnesses from the 07 car it could work pretty easy.
      06-03-2011, 12:44 PM   #9
arggg45
No_Country
11
Yes, because actually running the wires is so easy, even when you know what you're doing
/sarcasm.
-Mark Donohue
      06-04-2011, 05:07 AM   #10
Arxangel
Arxangel's Avatar
Bulgaria
16
/sarcasm.
Well in any case it is easier than trying to modify wiring and to program the ECU to work with other systems and another engine.
Tags
2004, 2007, dfference, z4 engine
