      10-29-2022, 04:43 PM   #1
gutus
Drives: 2006 535i
OEM Exhaust Alignment
Hello,
I have a 07 z4m coupe. I just realized that the OEM exhaust is hanging lower than normal from the rear. Is there a way to adjust the position of the rear mufflers?
Thanks
      10-29-2022, 04:48 PM   #2
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Use the two bolts connecting to the x pipe to adjust. Tighten or loosen each bolt separately to adjust to your preference.
Also, by turning the flange to different positions to adjust the direction of the adjustment..
HTHs,
FB Group-- > fb.com/groups/z4group
FB Page-- > fb.com/Skyermotorsport
      10-29-2022, 05:19 PM   #3
gutus
Drives: 2006 535i
Do you mean where the muffler connects to the x pipe near the rear axles? Thanks for your help!
      10-29-2022, 05:52 PM   #4
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
See this thread => https://www.bimmerpost.com/forums/sh....php?p=8832394
      10-30-2022, 11:24 AM   #5
maupineda
Drives: E86 Z4MC
Yes, it can be baffling at start but at least in my car the way to get the mufflers to rise I had put the flanges vertically and started bolting the “top” bolt to the point I needed to back off as it was now too high. One side could not be risen as much but enough to look spot on.
You need to make sure all mounts and supports are still good. Otherwise you will be chasing your tail.
      10-30-2022, 10:28 PM   #6
gutus
Drives: 2006 535i
Thanks for the link. That’s how I want mine to line up.
