05-05-2011, 11:43 PM | #1 |
Rep 1,603
Drives: Imola Red Z4MC
OBD-II-Code-P0301 - help
The car starting acting extremely strange just before i pulled into my street, prior to this i heard kind of a ringing noise, almost as if metal was vibrating.
Basically the car sounds like a west coast customs chopper right now, misfiring everywhere, gurgles pops u name it, the throttle is very sketchy, my ODB II scanner gave me 5 codes, 4 of them being 02 sensors from just installing my headers, the 5th was P0301 which is Misfire Detected in #1 Cylinder Can anyone tell me what could have caused this? What I can do to fix? My car is 06 if this is possibly a vanos-related issue that has not had the extended bolts replace the existing ones recently installed performance mods: AA headers, RPi exhaust, TCKline coils (dunno if this helps but thought i'd add it in) I was driving my car normally up to this point as well, maybe a few extra down shifts to hear my new exhaust set up opinions?
///M - Some Mods 'N Stuff
05-07-2011, 10:51 PM | #2 |
Rep 2,782
Are the O2 sensor codes for primary or secondary O2 sensors? Primary sensor malfunctions can cause a misfire.
Vanos bolts are definitely a possibility. There's a DIY check on here somewhere. IIRC you don't actually look at the bolts themselves; instead, you try to wiggle one of the VANOS gears and check it for play. The DIY is for the valve adjustment. Obviously don't drive the car. Edit: What's the build date of your car?
05-08-2011, 03:29 AM | #4 |
Rep 191
Check to see if your air intake / filter is properly attached and secured.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
05-08-2011, 08:47 AM | #5 |
Rep 331
I was just reading some post on the M3Forum.net with very similar symptoms and P0301 code. I think it was the VANOS solenoid in this guy's case.
... Edit: Here, I found it. Hope that helps narrow it down... http://m3forum.net/m3forum/showthread.php?t=330862 Good luck!!!
05-08-2011, 01:28 PM | #7 |
Rep 1,603
Thanks for the help guys, still looking into the problems myself, might just revert everything back to stock and flatbed to bmw
05-08-2011, 07:49 PM | #8 |
701
^ Always an option. If the problems persist then you can rule out your install. It's possible the install is simply coincidental and there's no correlation to the problems you're experiencing. In which case if it's under warranty I'd rather have it on their dime (and rightfully so since it would be independent of the mods).
05-12-2011, 11:32 AM | #9 |
Rep 987
When you install your coils it is possible to not push them in fully causing a misfire. I had that problem on my E46M. Make sure to push them in firmly before locking them in place. That's an easy check so I would definitely try that.
Also make sure you did not cross your 02 sensors. That will make you throw all kinds of codes. Give us the actual codes that you threw. There is also a fuse in the DME that sometimes gets blown which will throw half a dozen codes and put you in limp mode. Last edited by Jumbosock; 05-12-2011 at 11:37 AM.. |
05-12-2011, 12:46 PM | #10 |
Rep 1,739
Drives: 2008 Z4MC
^^^True. When you cross your O2's, your car will run like shyte. Giving the actual codes will help
05-12-2011, 01:21 PM | #11 | |
Rep 1,603
Car was shipped out to bmw today though, guess i'll let them deal with it, Wooo CPO'd car lol
05-16-2011, 04:58 PM | #14 |
Rep 1,603
Update:
BMW called back and said it was the bolts in the VANOS that came loose and fucked everything up, Warrenty IS covering it however and my car should be fixed sometime this week! So, to everyone with an 06, GO AND CHANGE THOSE BOLTS ASAP!
05-16-2011, 06:32 PM | #15 |
Rep 2,782
Wow. Another. How many miles?
05-18-2011, 02:17 AM | #16 |
Rep 987
Were you hearing any noises prior to this happening?
