08-23-2015, 10:20 PM | #1 |
Rep 180
I have a used (less than 500 miles) set of the RE motor mounts for sale: $250 shipped in the con US These mounts will make shifting on the ///M nice and crisp. Thanks for looking. Cheers! |
09-03-2015, 06:55 PM | #4 |
Rep 180
This is $380 brand new from EAS. I'm only asking $250 because it's slightly used. Someone jump on these ?
Here is description from EAS: Finally, a real performance engine mount for those looking for the extra edge. Until now, the only performance engine mount to really consider was the BMW Motorsport Group N engine mounts priced at an incredible $800/pair! These uber expensive mounts were just like factory engine mounts except they were produced with a harder rubber, approximately 30% stiff than stock. The Rogue Engineering Performance Engine mount is a affordable alternative to the BMW Motorsport Group N mounts, at a fraction of the price. Because these are produced with isolated mounting plates, it does offer similar vibration dampening characteristics like stock. Of course, because of the harder nature of these bushings, some additional vibration may be experienced, just like the BMW Motorsport Group N engine mounts. Just like factory, but better The factory-like design incorporates the anti-rotational tabs ensuring that the mounts do not rotate. Use of these mounts virtually eliminates all deflection created from the engine. This is especially true for high-powered vehicles such as those with turbos or superchargers. The internals of the mount feature a unique locking system in the event of a crash, the internal hardware of the mounts prevent complete failure of the mount. Whereas the integrity of the mount will be compromised, its internal construction prevents the mounts upper and lower plates from completely tearing away from each other. Whereas this may seem to be a small feature, this will ultimately decrease the chances of the engine from breaching the firewall, and entering the internal compartment of the vehicle. No other performance mount can make this claim. Additional Features These mounts are made to be 5mm lower (unlike other aftermarket mounts that are TALLER than stock!), lowering center of gravity. A spacer can be used to raise it to factory height, if necessary. Note: Because of the unique design of Kromer Kraft headers, we do not recommend using these mounts with this header system. Factory engine mount heat shields are required to be used with this product. Models Supported: 1995-1999 BMW E36 M3 1999-2006 BMW E46 3-Series & M3 2003-2008 BMW E85/E86 Z4 & Z4M |
