07-24-2013, 03:58 PM | #23 |
Rep 1,543
I just got this knob in my hand. if I'm going to switch the base, do I still have to separate the m5 knob and the boot?
If I separate them, do I have to break the white plastic ring inside the boot? reason being easier to change knob in the future; however, would the new m5 boot stay put without the plastic ring inside? thanks and will try to attack this tonight.
07-24-2013, 04:18 PM | #24 | |
Rep 2,550
I have no idea if the boot will stay without the plastic ring since I left the ring intact. |
07-25-2013, 01:50 AM | #25 |
Rep 1,543
I just installed this and took it for a drive. Wow. Much better weight and this is what I've been looking for. A tad taller and heavier than the ZHP I had. Since I have the AS SSK, ZHP is a bit too short, OE is weightless, I have been on the hunt for a perfect shift knob.
Since I change my shift knob, daily vs track, I have to break the knob/boot combo. I tried my best to keep the white boot ring intact. The trick is to cut enough of a slit for the wires to be able to edge it out instead of breaking the top boot ring. So M5 boot is in and I can just pull it to change at my hearts desire. Now, I have the M5 knob for daily and a taller metal knob for the track (don't care about too hot/cold since I wear gloves for track) For those who cares, ZHP weights 152 grams and the M5 weights 169 grams. |
07-25-2013, 11:30 AM | #26 |
Two Wheels or Four?
93
Rep 655
Anyone know how much the M Performance knob weighs?
Current: '18 AW Performance Edition m240i Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci |
11-09-2013, 01:10 PM | #28 |
Rep 350
Guys,
Leatherz has done the comparison. Same hight and circumference. Slightly lighter than ZHP by a couple ounces. Side-By-Side Comparison Click for larger pictures F10 M5 Shift Knob Illuminated ZHP Shift Knob Respectively: Weight 6.0 ounces 6.3 ounces Height 76mm 76mm Circumference at widest point 164mm 164mm |
