07-06-2017, 03:58 AM | #1 |
Rep 29
Cold Start Issues
I have just bought my Zed (Automatic) and I am experiencing some cold start issues, after starting revs fall really low and usually recover but sometimes the engine stalls - this lasts for 20 to 30 seconds.
During this period if I put my foot on the brake pedal to select drive from park the revs go up and down quite violently for about 20 to 30 seconds, once it settles down I can select drive and proceed normally. This only happens from a cold start, when the car has warmed up it behaves normally, has anybody also experienced this and what was the fix? |
07-06-2017, 06:49 AM | #2 |
Rep 2,702
Sounds like a vacuum leak somewhere.
Also check/clean the ICV(Idle Control Valve)
07-06-2017, 06:59 AM | #3 | |
Rep 29
I see you are from Kitchener, Ontario - not too far from Kincardine, Ontario where I lived in the early 80's whilst working at the Bruce Nuclear Power Development. |
07-06-2017, 07:12 AM | #4 |
Rep 2,702
Small world.
Spent many long hours at the Bruce.
07-22-2017, 05:14 AM | #6 |
Rep 29
It would seem that the issue is not resolved, more hoses found perished and cracked and replaced and this was to no avail either.
Real culprit was the cheap generic MAF that had been fitted, branded Hella MAF fitted and everything is now as it should be. |
07-22-2017, 12:31 PM | #7 | |
701
Enjoy! |
