07-05-2017, 08:39 AM | #23 |
Rep 71
got the Michelin pilot sport AS3 mounted Monday and they feel great! very little road noise, excellent grip, less tramlining, and less bone shaking when hitting those speed bumps or pot holes.
whats the proper PSI for these michelins? IIRC, the manual says 33 front and 38 rear but I think those are run flat numbers. |
07-05-2017, 09:16 AM | #24 |
Rep 2,051
I think the Michelin Pilot Super Sports are probably a lot more comfortable than you'd think because they are softer than some of the ultra high performance tire alternatives. I can attest that they have both loads of grip and long tread life! Worth considering IMO. Be forewarned though, when going from RFT to non-RFT you may find the chassis and suspension overall feel softer because they were designed for a rigid tire.
I'm debating MSS on my Z4 M but I'm actually worried it might soften the ride too much and since its my summer sports car I don't necessarily want to soften it up. |
07-05-2017, 09:19 AM | #25 | |
Rep 2,051
07-05-2017, 09:35 AM | #26 | |
Rep 4,365
For reference my truck recommends 32psi (factory tires) but the slightly larger LT rated tires I put on recommend 45psi. Quite the difference and because of the type of tire (LT vs 4 ply). I would expect the Run Flats to be different as well since they are a different construction than a traditional tire.
07-11-2017, 02:26 PM | #28 |
Rep 71
Along with the tire mounting I also got a full roter and pad replacement. So now my brake pedal is a little mushy. I felt what I can best describe as bubbles or pops in the breaks on the 2 day of driving. Any advice on what this could be? I had new break fluid less than a year ago so the fluid was replaced with the breaks.
07-11-2017, 02:31 PM | #29 | |
Rep 2,704
07-11-2017, 03:52 PM | #30 |
Rep 4,365
Yup - I'd say they didn't bleed the line enough. Take it back to whoever changed your brakes.
07-12-2017, 06:27 AM | #31 |
Rep 4,057
Now this is weird. Yesterday, I used the chat feature to talk to a rep at Tire Rack about my Michelin Pilot Super Sports that I bought from them last summer. The rep that I chatted with advised me to inflate per the sticker on the door frame.
Huz-Z
07-13-2017, 05:34 AM | #32 |
Rep 2,051
Yes and here's why I believe that is correct as a guideline. Tires have a maximum amount of pressure they can hold and it is different for each tire. But your car's chassis and suspension are designed for a certain tire size at a certain psi. If you changed tire sizes or tire classes I could see this guideline being less meaningful but if you keep the same tire class and size you shouldn't deviate significantly from BMW's guideline if driving on the street most of the time. +2 PSI over recommendation seems to be the most common approach I've seen on forums and works well for me also. I followed this model even when I switched from RFT to non RFT because the chassis was meant for a harder tire but by putting on a softer tire the chassis got a bit sloppy and so did the steering. 2+ PSI helped compensate for that.
07-13-2017, 06:32 AM | #33 | |
Rep 4,057
Huz-Z
