      06-10-2014, 01:42 PM   #1
papak
Drives: 2008 Z4 3.0si Coupe
E86 Steptronic fill port
OK, where is the fill port on the Steptronic transmission?
      06-11-2014, 06:32 PM   #2
papak
Found it! Drivers side of transmission, adjacent to the drain plug, just above the plastic pan seam. 8mm hex. No room for a ratchet unless you can find a short 8mm hex bit that fits a ¼" ratchet, You won't be getting a torque wrench in there.
