      06-03-2014, 07:41 PM   #23
pungo
pungo's Avatar
@ @007MCoupe ...done
They work with just about everything, but IIRC some that have a fixed nut on them would have to be removed 1st.
IIRC, Stromung uses the welded on nuts. Does this mean the welded on nut needs to be removed? Wouldn't the bolt supplied with the new hanger thread into the welded on nut? Has anyone used these hanger with Stromung without modification?
BTW, my Stromungs hang perfectly after fine tuning the alignment to fit the bumper opening. I just want to reduce the deep vibration in the 1800-2100 rpm range under medium throttle and thought these hanger might help. Any experience with reducing vibration with Stromung mufflers?
      06-03-2014, 07:45 PM   #24
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
It would depend on the size of each one.
I have the same thing with Eisenmann. I plan to just cut it off...
      06-04-2014, 10:30 PM   #25
sabbanick
Drives: 08 SBM M coupe
What the hell... Peaked my interest.
      06-05-2014, 08:11 AM   #26
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
does that mean you are in
      06-05-2014, 08:40 PM   #27
fdagen
Drives: 2006 Z4M Roadster
I'm in
      06-07-2014, 06:08 AM   #28
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Weekend
GB closes end of June
      06-09-2014, 10:39 PM   #29
Cyclops
Cyclops's Avatar
Weekend
add me in
      06-09-2014, 11:20 PM   #30
dorifto88
Drives: 88 Nissan Pathfinder
and me, dangit
      06-10-2014, 02:20 PM   #31
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
@ @Cyclops & @dorifto88
..done
      06-17-2014, 06:46 AM   #32
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Just a reminder GB ends June 30th
      06-17-2014, 07:51 AM   #33
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Anyone installed these with a stromung exhaust? Any issues?
      06-17-2014, 10:35 AM   #34
bjbstewart
bjbstewart's Avatar
Drives: 2007 BMW Z4MC
Just checked the stock mufflers. The bolt also threads into the bracket, so the Eisenmann's and Stromung's are just duplicating how the stock setup is with the nut welded on.
Sounds like with stock, Eisenmann, and Stromung - they will all have to be castrated to work with this hanger?
[SIGPIC][/SIGPIC]
      06-17-2014, 11:06 AM   #35
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yes de-nutting is required.
      06-17-2014, 11:08 AM   #36
bjbstewart
bjbstewart's Avatar
Fine then. Please add me to the list.
[SIGPIC][/SIGPIC]
      06-17-2014, 07:40 PM   #37
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6344
i have these installed with my rpi. great adjustability and superb design and construction.
instagram: @ dubsesd
      06-18-2014, 10:20 AM   #38
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks
      06-18-2014, 10:20 AM   #39
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
done.
      06-18-2014, 11:30 AM   #40
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
I assume you had to castrate your mounting points? How much reduction did it give you for the drone (just ball park percentage).
      06-18-2014, 11:49 AM   #41
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ yes same thing with RPI
all thats needed is a quick Dremel job on a nut.
      06-18-2014, 11:51 AM   #42
dorifto88
This is going to sound selfish but would anyone have any objections to ending this group buy early to expedite things? Lol
      06-18-2014, 12:16 PM   #43
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I'll ask.
....done..........
Its been pretty quiet since we reached the target. DKF has agreed that it will close early
GB Closes on June 20th
After the GB has closed send PP to;
dkfperformance at gmail dot com
Include your screen name in the payment message.
Payment is required by June 29 to get production rolling.
      06-18-2014, 04:38 PM   #44
Arrgo1
Not so new member
Arrgo1's Avatar
Drives: 2006 M Roadster
Nicely done!
