Go Back   ZPOST > Marketplace > Sponsors Classifieds
      08-21-2012, 05:26 PM   #45
Expert@ApexWheels
Expert@ApexWheels's Avatar
3511
Drives: M3
Hyper Black ARC-8s on this Z4MC:
We have many sets of ARC-8s in stock currently. Give us a call if you'd like to order a set!
      09-05-2012, 02:35 PM   #46
ApexWheels
ApexWheels's Avatar
1422
Drives: M3
ARC-8's in Z4 fitments are in stock!
Please call us with any questions you may have regarding fitment
      09-16-2012, 09:57 AM   #47
OneManParty
Drives: Z4m
Will 18.9.5 et 35 square 265/35 work on a 07 z4m on stock suspension?
      09-17-2012, 01:01 PM   #48
Expert@ApexWheels
3511
Drives: M3
Depending on the tire you choose, you will need to dial in at least -2.5 degrees negative camber in front (especially with extreme performance tires such as the Hankook RS-3).
      09-25-2012, 04:34 PM   #49
ApexWheels
ApexWheels's Avatar
1422
Drives: M3
ARC-8's are in stock in Z4M and Z4 fitments!
Give us a call, email, or pm with any questions and concerns regarding wheel fitment.
      10-01-2012, 03:26 PM   #50
ApexWheels
ApexWheels's Avatar
1422
Drives: M3
ARC-8's are available for your Z4 or Z4M! This car is using 18x9.5" ET35 front wheels with 255/35/18 tires and 18x10" ET25 rear wheels with 275/35/18 tires. The tires are Hankook RS3's and wheels are Satin Black.
Please call, email, or pm us with any questions you may have.
      10-03-2012, 03:22 PM   #51
Expert@ApexWheels
3511
Drives: M3
ARC-8s in Z4M fitment are in stock in multiple sizes!
Give us a call if you have any questions regarding fitment!
      10-05-2012, 07:01 PM   #52
ApexWheels
ApexWheels's Avatar
1422
Drives: M3
ARC-8's are available for your Z4 and Z4M in multiple square and staggered fitments!
      10-08-2012, 06:03 PM   #53
Expert@ApexWheels
3511
Drives: M3
Satin Black ARC-8s on this Z4M Roadster:
We have every finish of the ARC-8 in stock right now!
      10-08-2012, 06:16 PM   #54
avsbmw
Drives: 07 Z4MC
Originally Posted by RandysV10 View Post
Will the 18x9.5 et35 square set up with 265/35/18's R-Comps fit with a BBK? Spacers needed?
Randy... Very interested in this set up. I am running my arc-8 track wheels as my street setup and will be changing up my track set up.
265/35/18s square set up with some camber plates on H&R coil overs would work right?
      10-09-2012, 03:34 PM   #55
ApexWheels
ApexWheels's Avatar
1422
Drives: M3
A 265/35/18 square set up on your Z4 is very doable with the required negative camber in the front. Depending on the type of tire you end up using we like to see at least -2.5 degrees of camber in the front or maybe more if you are using a wider extreme performance or R compound tire. Additionally a small 3-5mm spacer may be needed for the tire to clear the strut tube. Before installing the wheels we also recommend checking clearances against your H&R coilovers. Sometimes the ride height adjuster and spring need to be adjusted up to make more room for the wheel and tire. Otherwise you will need to use a wheel spacer to for added clearance.
      10-09-2012, 05:36 PM   #56
avsbmw
Drives: 07 Z4MC
I plan on running R compounds so would a 245/275 set up be better?
      10-09-2012, 05:37 PM   #57
avsbmw
Drives: 07 Z4MC
I don't want to have any rubbing issues in the front.
      10-10-2012, 05:51 PM   #58
ApexWheels
ApexWheels's Avatar
1422
Drives: M3
Camber plates are not only used as an aid in fitting wider wheels and tires but also as a tool in tuning the car and a performance enhancement. Any wheel and tire set up can benefit from camber plates because a person can use more of the tire's tread effectively when under cornering loads. A 245/40/18 R compound tire is a very wide and tall tire and would still need camber plates in the front. Comparatively a 245/40/18 R compound tire could be sized the same as some 265/35/18 street tires. The only 245/35/18 R compound tire that any tire manufacturer produces is a Kumho V710 that utilizes older tire technology and is not favorable compared to the Nitto NT01 or Toyo R888.
      10-11-2012, 05:29 PM   #59
Newff
Newff's Avatar
20
Drives: 2008 BMW Z4 3.0si
Location: Fort Mcmurray, Alberta/ Hare Bay, Newfoundland
Anyone have a rim split yet? My father called me today (he is using my car while I'm out of province) and told me he was having problems keeping air in the tire and they couldn't find hole at the shop but then realized the rim was split. No track use just regular use.
      10-11-2012, 05:32 PM   #60
ApexWheels
ApexWheels's Avatar
1422
Drives: M3
I'm sorry to hear you're having an issue with one of your wheels. Many variables can increase the likely hood of wheel damage on the street such as a stretched tires, run flats, but even with the most ideal setup a bad pot hole or other harsh impact can damage any wheel available on the market. We've sent you a PM requesting details about the issue, so that we can better understand what you've experienced. We'll use this information to process a warranty replacement if eligible.
      10-16-2012, 03:11 PM   #61
Expert@ApexWheels
3511
Drives: M3
We've got ARC-8s in stock and ready to ship in most finishes!
Tags
apex, arc-8, flow formed, track wheels, wheels
