      04-07-2014, 03:38 PM   #1
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
Is the resonator/muffler the source of the drone?
I've driven straight piped cars before. None of them drone as terribly as my Z4M w/ muffler delete, replaced with resonators. I have heard that the RPI exhaust (I think?) drones a lot too. My drone seems to be more vibration based, in that even if I put earplugs in, the volume isn't decreased all that much. It's a really deep drone.
So, I'm wondering... do you think that the exhaust gases flowing through the resonators are attenuating the sound heard from the outside, but transferring that energy in the form of vibrations throughout the rest of the car?
Maybe the only thing I can do to test is remove the resonators completely and drive around the block just dumping the exhaust after the axle. Do straight piped Z4Ms drone a lot?
Physics isn't my strong suit, so please forgive me if everything I just wrote is crap.
      04-08-2014, 04:39 PM   #2
h3patik
Drives: BMW Z4 2.5
Hi,
Delete the resonators and add just a good backbox
      04-19-2014, 12:33 AM   #3
intoflatlines
So I tested by removing the resonators/mufflers and it still had drone. It was reduced a little bit. Exterior noise was noticeably louder. It was very raspy under WOT. Not worth it for the minor reduction in drone.
You're saying to get an aftermarket X-pipe? And different mufflers? Any custom options for standalone mufflers or are people just buying the pre-made setups?
      04-20-2014, 11:30 AM   #4
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
The s54 is a noisy motor you need resonators closer to the headers to kill rasp and most drone...but it will always drone
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      04-22-2014, 11:04 AM   #5
p1nk50ck
HNIC
Drives: Z4M Coupe
http://www.zpost.com/forums/showthread.php?t=747182
http://www.dkfperformance.com/products.html
these might help?
      04-22-2014, 12:43 PM   #6
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
There is a thread out there of creating a horseshoe or U shaped pipe at specific length to remove drone. Decent amount of science behind it but is proven to work. If you're already custom exhaust all the way through you might want to give this a try with a muffler shop or someone who has welding capabilities. I'll see if I can find the thread.
      04-22-2014, 12:55 PM   #7
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Skiddish has it right, there's a way to cancel drone.
Here is the thread re: U Pipe.
And reference material.
      04-22-2014, 01:30 PM   #8
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
This man's got it. Thanks for digging for me!
      04-26-2014, 01:18 AM   #9
Finnegan
Finnegan's Avatar
You're welcome! Have it book-marked, since it's on the "to do" list for after moving day.
