10-24-2010, 03:04 PM | #1 |
Rep 91
Drives: 2007 Z4MC
06 Z4M R Vanos Cam Bolts
I have a 06 M Roadster that is now out of warranty and I would like to replace the vanos bolts that have been known to break while the car is in winter storage. I have a TIS but can't seem to find the repair proceedure/ special tools required to complete this operation. Any suggestions?
Thanks Wayne |
10-24-2010, 04:22 PM | #2 |
Rep 11,667
Here's a detailed DIY.
FWIW, proceed with due caution, this isn't the normal run of the mill DIY. If you don't have experience with engine internals you could easily get in over your head.
10-24-2010, 04:31 PM | #3 |
Rep 4,726
OMG NO, that is NOT an acceptable way of doing that by a long shot. There's no way he managed to keep his timing with those sharpy marks nor did he pretension the vanos on reassembly.
Spinning the engine backwards using the fan is also not acceptable.
10-24-2010, 04:53 PM | #4 | |
Rep 1,143
10-24-2010, 05:05 PM | #5 |
1M advocate
213
Rep 878
haha nah he means he wants to replace the bolts while the car is down the for the winter... not that winter storage contributes to the breaking of the bolts.
2012 BMW S1000RR
2011 BMW M3 |
10-24-2010, 05:37 PM | #6 |
701
It's looking more and more like a good idea to check/replace these bolts if you have an 06. There really should be a TSB or a recall, but I'm not holding my breath for one to be issued.
Compared to the cost if they go...well, it's not cheap to do but way cheaper than the alternative. |
10-24-2010, 05:57 PM | #8 | |
701
In other words, don't try this at home or at the dealer... |
10-24-2010, 06:09 PM | #9 | |
Rep 11,667
It would also be helpful to know when the bolt change was made on the '07 MY as well.
10-24-2010, 06:17 PM | #10 | |
Rep 4,726
I looked at it again though, so long as you move the cams to full stop before disassembely, it is possible to do this without technically re-timing the engine. You cannot do this without the solenoid tool though, and you still have to pretension and follow the rest of the reassembly which that guy did not. He just tried to match everything back up and stick it back together. The locking tool is also non optional, the slightest bit of play in what you use to lock the engine at TDC will result in improper timing, the BMW tool is precision machined, I've rotated the engine over 10 times before because I kept barely missing the hole. http://www.adrianteo.com/files/RA%20...ng%20_S54_.pdf I'll be checking this on a car tomorrow actually.
10-24-2010, 07:00 PM | #11 |
Rep 606
FWIW, I have an '06 that's been tracked regularly and, knock on wood haven't had any issues and I'm coming up on 50K miles on the car. Every time I start and stop the car from my garage I listen for the issue. So far so good.
PS - Finnegan, are you Wayne who has the half cage I copied? If yes, this is Jared!
10-24-2010, 07:36 PM | #12 |
code monkey
Rep 74
My dealer charged me less than $800 to replace them, so if you're like me and not mechanically inclined, I'd suggest finding a good indie shop and you'll likely get it done for less than that. If you are hearing any noise, I'd get it checked out immediately. Here's the pictures of my bolts that were replaced.
10-24-2010, 08:15 PM | #13 | |
701
10-24-2010, 08:17 PM | #14 | |
Rep 4,726
10-24-2010, 08:18 PM | #15 | |
701
10-24-2010, 08:37 PM | #16 | |
Rep 4,726
10-24-2010, 08:44 PM | #17 |
Rep 1,143
10-24-2010, 08:51 PM | #18 |
Rep 2,863
10-24-2010, 08:56 PM | #19 |
Rep 4,726
I don't think it's the bolts themselves, Just that when replaced they are torqued properly and locktighted. The bolts are the same grade as far as I know.
10-24-2010, 08:57 PM | #20 | |
Rep 4,726
:serious face: I never kid.
10-24-2010, 09:03 PM | #21 |
Rep 2,863
Right, I'm hoping that by the end of the model year, BMW have learned enough about this that locktight and proper torqued were used to build these engines. I'm still somewhat concerned and will definitely have these checked during my valve adjustments.
10-24-2010, 09:06 PM | #22 |
Rep 4,726
They were building them for 6 years before the z4s got them, I'm going to say no.
