      01-29-2014, 06:55 PM   #1
3002 tii
3002 tii's Avatar
2286
My Car Weighs Less than 3000lbs
Well sorta, 3023lbs to be exact but this was after I had a rollbar installed which was probably 80-90 pounds of material so means I was closer to around 2930. This is with a near empty gas tank without driver.
Only signifiacant weight reduction was replacing factory M-sport heated seats with Recaro PP's and associated hardware, aftermarket exhaust and lightweight rims (18" Volks ~ 18lbs, 17" TRM < 17lbs). I still have factory trim in place and my car has oe navi system.
From what I gathered online, stock 3.0si coupe weighs in at 3100lbs, fully loaded probably closer to 3150lbs. Initial reading prior to any adjustment
Follow for latest mods
      01-29-2014, 07:13 PM   #2
Walkurie
Walkurie's Avatar
Drives: 06 M Roadster / 99 Jaguar XK8
It does make a big difference. With your engine mods, what do you calculate your power:weight ratio to be?
      01-29-2014, 07:19 PM   #3
3002 tii
3002 tii's Avatar
2286
Haven't dyno'd but I know stock 6MT dynos at 220-225whp. I'm sure the tune and exhaust add maybe 10hp to wheel max.
      01-29-2014, 07:25 PM   #4
shaheen@Z4MCbuyersguide
Drives: Car
Great figures, have always loved the look of your car.
      01-29-2014, 07:31 PM   #5
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Jealous
Shedding the seats is by far the best weight loss/money ratio.
      01-29-2014, 08:30 PM   #6
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Originally Posted by Kgolf31 View Post
Jealous
you forgot battery
      01-29-2014, 08:40 PM   #7
Kgolf31
Kgolf31's Avatar
460
Originally Posted by ZStig View Post
you forgot battery
Depending on the battery, it can get pricey...but you're right.
LTW Batteries can help a ton.
      01-29-2014, 08:47 PM   #8
3002 tii
3002 tii's Avatar
2286
On topic of batteries, I stick with oem replacement from Autozone. Don't drive car enough to use a lightweight battery.
      01-30-2014, 08:09 AM   #9
3002 tii
3002 tii's Avatar
2286
Thanks and much appreciated
      01-30-2014, 10:20 AM   #10
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Sweet! I'd like to weight my car just for S & Gs
      01-30-2014, 11:46 AM   #11
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
If you want a lightweight battery, Deka makes all of the lightweight batteries sold under other names, including the popular Braille batteries. They have one thats 7 lbs if you live in a warm climate, otherwise theres a 12-14 lb one that still provides cranking amps in the cold.
Most of the cost seems to be in the mount. But if you have access to sheet metal fab equipment, that pretty goes to zero.
