01-26-2014, 12:49 AM | #1 |
Rep 1,002
Car overheated after Dealer performed coolant flush
Hello guys, i need some advices. My brother-in-law brought his 328i to the dealer to have the coolant system flush done. The car was got overheated and put on Limp Mode after a week. I was suspecting they screwed up the coolant service and left air bubbles in the coolant system which caused overheat and damaged to the water pump and Thermostat. We brought it back to the Dealer and they confirmed the Water Pump and Thermostate needed to be replaced. However, they denied responsibilities and said we have to pay to get it fixed.
We are trying to get them to own up to it and take care of the problems and now they said we will have to wait til monday for the Service Department Manager to make the decision. What do you guys think? What are our options? |
01-26-2014, 09:10 AM | #2 |
Rep 104
Did anyone check the coolant level after the overheat issue, before returning it to dealer? If not you have no way of proving that they left air in system. Sometimes things just break at the most suspicious or worst times.
01-26-2014, 10:12 AM | #3 |
Rep 1,002
That is a good suggestion! We did not check the fluid level. However, i dont think fluid level would tell us too much (unless it is very very LOW). From what we read on other Bimmer forums, it didnt take much air trapped in the coolant loop to cause overheat and lot of damage. The 328i has electric water pump and has very specific procedures for bleeding/venting after coolant flush.
http://www.e90post.com/forums/showthread.php?t=24818 |
01-26-2014, 08:28 PM | #4 |
Rep 231
I'd raise hell. Ask for the GM and/or email corporate, and post it on the dealerships facebook page as well. It was working fine before the service and it goes out right after the flush? I call bullshit. I get that things break down, but c'mon, right after you take it in for service? screw that, I'd be livid.
01-26-2014, 11:25 PM | #6 | |
salty cowboys fan
6159
Rep 3,408
Which dealer was this at? |
01-27-2014, 12:22 AM | #7 |
Rep 1,002
01-27-2014, 12:25 AM | #8 |
Rep 1,002
01-27-2014, 08:38 AM | #10 |
Rep 1,107
Hold on, a week passed between when you got the car back and it overheated? How many hours/miles was the car used during that week and was it put into a situation previously during that week where it might have overheated (stuck in traffic or high outside temperature)?
If the dealer screwed up the coolant service, my thought is that it would have failed earlier in the week. |
01-27-2014, 11:03 AM | #11 | |
Rep 1,002
01-31-2014, 03:09 PM | #12 |
Zed Head
314
Rep 233
Drives: 2020 BMW Z4 M40i
If there was air in the system the car would have overheated in a matter of minutes of driving it, just sitting and idling it would take conciderably longer but driving of any type would cause and overheat situation probably in just one or two miles. If your car experienced vapor lock there is no way you would drive 50 miles before overheating unless you did it in 1 mile increments. It happened to my Z4 in December when I had the system flushed. The temp gauge pinned to the right and a red idiot light came on, I shut it off waited ten minutes and the air bubble moved, the temp went down immediately and the radiator was down about a half gallon, refilled it and no problem after that. The water pump did fail suddenly a year and a half ago at about 80K the car had 100k when I had the system flushed. At that time the car overheated within a half mile of the pump going.
01-31-2014, 11:18 PM | #13 | |
Rep 1,002
Anyhow, seeing that is possible that the water pump could have fail on its own and will need to be replaced anyhow. We agreed to pay for the parts and the dealer provide free labor. The bill came out to $656! We thought that was fair and dont want to drag it out any longer. Needless to say, we wont coming to that shop anymore. Thanks everyone for the inputs. |
02-03-2014, 07:57 AM | #14 |
Mechanical Engineer
96
Rep 1,025
Pretty gracious of you to accept that compromise I think. Thanks for warning us about that dealership, I'm hoping to move out there soon and I'm really bummed that I'm going to lose my absolutely stellar indy mechanic here in PA. He's probably the only mechanic I've ever trusted enough to preauthorize work without cost estimates.
