12-26-2017, 10:26 PM | #1 |
Rep 69
Z4 N52 DISA Issue
Hello,
I am trying to troubleshoot the DISA on my Z4 coupe. I got the error code 2AAC: Variable Intake System 2. I pulled the larger DISA out and found that the problem is the larger DISA valve does not close all the way when I start the car. It stays partially open. There is no rattle and the flapper is not loose. The flapper doesn’t seem to move when I try to push it. EDIT: The valve doesn’t close all the way because I didn’t fully pull it out to check It. It works now.
Do it yourself Illustrative site.
http://diyrabbit.com/ Last edited by rocky79; 01-03-2018 at 12:04 AM.. Reason: Delete post |
