      12-26-2017, 10:26 PM   #1
rocky79
rocky79's Avatar
Drives: 2007 Z4 Coupe 3.0SI
Z4 N52 DISA Issue
Hello,
I am trying to troubleshoot the DISA on my Z4 coupe.
I got the error code 2AAC: Variable Intake System 2.
I pulled the larger DISA out and found that the problem is the larger DISA valve does not close all the way when I start the car. It stays partially open.
There is no rattle and the flapper is not loose. The flapper doesn’t seem to move when I try to push it.
EDIT:
The valve doesn’t close all the way because I didn’t fully pull it out to check It. It works now.
Do it yourself Illustrative site.
http://diyrabbit.com/
