      10-05-2013, 11:46 PM   #1
Yvette
Drives: M
Would 225/40/18 tires work for winter?
225/40/18 all around,would it work?
      10-27-2013, 05:44 PM   #2
Yvette
Drives: M
anyone can verify?
its for moupe
      10-27-2013, 05:55 PM   #3
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
More info, as in what wheels they will be mounted to...etc
      10-27-2013, 06:34 PM   #4
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
Undersize diameter compared to stock
instagram: @ dubsesd
      11-05-2013, 12:45 AM   #5
Yvette
Drives: M
stock wheels
      11-05-2013, 05:36 AM   #6
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Will it work? yes, it'll work. It'll be under sized, the rear tires will be stretched on a snow tire (225 on a 9" wide), the car will be closer to the ground for driving in the winter. So it's not optimal but you can drive on it. I would stick with OE size or 245/275 which I've done for 2 year in Vancity winter.
      11-05-2013, 09:45 AM   #7
p1nk50ck
HNIC
Drives: Z4M Coupe
will it work? yes. will it be optimal? no.
you want a skinnier wheel/tire and a larger sidewall (and obviously dedicated snow tires)
