10-21-2017, 05:18 PM | #1 |
Rep 1,351
Drives: in Anger.
2007 BMW Z4M Coupe
2007 BMW Z4 M Coupe This car is #1217/1815 made. Mileage: 57,000 est. Interior: • Black Nappa Leather with Carbon Leather trim. • Regular Detailing with Griots Garage products. • Navigation System • Rubber mats. Carpet M Trunk mat. • ZHP Weighted shift knob. Original included. History:First owner had vehicle for a year or so and 2500 miles. This vehicle was purchased from Rick Hendrick BMW in Hickory, NC by Texan. He then traded it back in there and Rick Hendrick purchased it Back from the Texan. All service performed at a BMW dealership during the Texan's ownership. I bought from Rick Hendrick BMW with 16,916 Miles and had it shipped over to Seattle. All of this is reflected in the Carfax which is clean. Wheels and Tires: • Sportlines CS.16 CSL forged wheels -19x8.5 ET35mm -19x9.5 ET22mm Tires: Bridgestone Potenza RE-11s 245mm (F) 275mm (R) Suspension: • H&R lowering Springs • OEM BMW Shocks Lightweight Battery Installed: I used a Odyssey PC1200MJT with a piece of Delrin and milled it to match the OEM battery bottom. Then bonded that Delrin plate to the battery. Presto! I have a small lightweight battery with the factory OEM mount with no modifications. No tender but I do drive once a month minimum. Engine: S54 3.2L inline six. 330hp. Same as e46 M3 • Regular servicing from Broadstroke associates and BMW Seattle (In my ownership) or BMW dealership (Previous owner). • Regular oil analysis from blackstone labs at every oil change during my ownership. Oil Changes (Miles): - 1,350 - 11,915 - 16,891 - 23,475 - 28,818 - 33,084 - 36,718 - 42,488 - 45,342 - 46,348 - 50,571 - 57,201 • Rod bearings replaced with coated bearings (45,342 Miles) • Vanos hub and unit replaced with Cryogenically treated upgrade version. • AFE Intake system. • Euro Cats, plug right into Stock sensor harness. • Very rare OEM BMW M3 CSL Headers ( lighter than euro headers and eliminates 2 of the stock cats but with no codes and passes emissions no problem. Amazing sound.) • UUC Transmission Mounts OEM BMW Carbon Fiber Spoiler. Will come with BMW indoor/outdoor car cover. Owned by BMW CCA 10+ year Member Not abused or raced. Clean title and carfax
Gone (2006 STI, 2008 EVO MR, 1968 Mustang)
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! Last edited by Swashplate; 11-28-2017 at 04:33 PM.. Reason: add carfax info. |
10-25-2017, 07:20 PM | #4 |
Proud E86M Owner
79
Rep 650
It should pass if the cats are working properly in section 02 (Spipe) But is California x-x might be risky. However, this M comes already with the best Section 2 out-there (hard to find too) and probably the only proper one for the state of California, other ones most likely would not pass for sho.
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute) 2016 Honda CR-Z EX Jet Black (Daily Commute) 2008 Kawasaki ZX6R Plasma Blue (SOLD) 2008 Z4///M Roadster Space Gray (SOLD) |
10-25-2017, 07:27 PM | #5 |
Rep 1,351
Drives: in Anger.
Cats are working properly, as if it was a factory installation. No CEL and recently passed Smog in WA state, with the OBDII plug. I will investigate but I don't see why it wouldn't.
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! |
10-26-2017, 09:06 AM | #7 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Bump for a very nice coupe. This is a better bargain that what it may first seem. With the vanos and bearings addressed, this baby is good to go. It also has custom wheels, the additional aero side skirts, and the weighted shift knob. Add up the vanos and bearing work if done in a shop and the custom parts, and that's $7000-8000 value. You may find a less expensive coupe with 25K+ more miles, but it probably still has the original vanos and bearings, and everyone that owns these will eventually have to do vanos and bearings work. These are the major ticket maintenance items for the S54 engine, and it's already done on this car.
Salty
10-26-2017, 09:58 AM | #8 |
1821
Rep 5,337
^WHS.
At 10 years old, these cars are going to NEED some maintenance. I'm starting to find a lot of plastic parts disintegrating and hoses failing. A well cared for car is worth its weight in GOLD. Back when the E30 M3s were starting to climb in value (in the early 2000s), the rule of thumb was, you find an E30 M3, and you'll end up paying $15,000 for it one way or another. You can either come across a pristine one with very few things needing repairs, that will command $15,000. Or you can find a nice example but a little up in miles and some wear and tear for $12,000, and you'll end up putting $3,000 into it to fix it up for the next few years. Or you can find a raggedy, $7,000 example with 100,000+ miles, and spend another $8,000 to make it road and collection worthy. There's just no two ways about it. I can list my MZ4 Coupe for sale if I should desire, and I think it will fetch $28K easy. But, even with all the work I've done on it, it still rides on the factory bearings and factory VANOS. Given the track miles it will likely need new RTABs and some of the suspension bushings (diff, rear lower control arm), and eventually engine mounts and tranny mounts as well. That's $4,000-6,000 worth of work for a $28K car. Unless it's not the color combo you want, you're much better off paying for a car that has all the work done for it and paying more. The reason I'm holding off on some of the major maintenance upgrade, is I don't plan on selling the car. The bearings will be taken care of when lead numbers creep up. The VANOS is not a preventative maintenance in my book. The bushings are still in OK shape, although I will likely start tearing the back end apart next year to start replacing them. The engine and tranny mounts will be replaced as they fail. Shockingly the steering hoses are in great shape, most of the coolant lines are in good shape. Eventually they will all need to be replaced on a preventative schedule.
10-26-2017, 10:30 AM | #9 |
Rep 870
Hack, the reason I consider VANOS preventative is because of the exhaust tabs breaking off, the seals deteriorating, and the sprocket bolts backing out on early models.
My intake sprocket was knocking around loose as a goose with bolts about to part like the Red Sea. Salty
10-26-2017, 10:50 AM | #10 |
1821
Rep 5,337
Last time I did the valve adjustment my mechanic upgraded the bolts and properly tightened it. So preventative or not, it's something you should take a look at every time the valve is adjusted, I suppose.
I was told that there really is no real "solution" to the VANOS tab issue, that even the fancy Dr VANOS "upgrade" is no guarantee that the tabs won't fail, and it is definitely one of those "keep a close eye" but replace when it breaks type when I suggested it to my mechanic. Everyone has their different level of tolerances to risks I suppose.
SaltyNC369.50 |
10-26-2017, 12:11 PM | #11 |
Rep 1,351
Drives: in Anger.
No they were lost at sea. Or stolen from my storage unit.
10-26-2017, 12:12 PM | #12 | |
Rep 1,351
Drives: in Anger.
10-26-2017, 01:04 PM | #13 |
Rep 4,057
Absolutely gorgeous car.
I am impressed with how lucid you seem in your posts because you must be totally off your rocker to be selling this beauty.
Huz-Z
SaltyNC369.50 |
10-26-2017, 06:29 PM | #14 | |
Rep 1,351
Drives: in Anger.
I cant believe it myself. But it is time, I need a motor the whole family can enjoy and perhaps it is time for something different.
JP's M2xx20.00 |
11-06-2017, 04:52 PM | #15 |
Rep 1,351
Drives: in Anger.
Ok, fresh oil service. Clean bill of health. Attached.
11-11-2017, 02:14 PM | #16 |
Rep 1,351
Drives: in Anger.
CarFax attached.
Carfax Attached.
11-14-2017, 10:48 PM | #17 |
Rep 1,351
Drives: in Anger.
Still available, attached is most recent oil analysis.
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! Last edited by Swashplate; 11-18-2017 at 11:44 AM.. |
Jsinghzzzz76.50 |
11-19-2017, 07:57 PM | #18 |
Rep 1,351
Drives: in Anger.
Available. Let's put this under your tree or whatever similar holiday symbol you prefer.
11-28-2017, 04:34 PM | #19 |
Rep 1,351
Drives: in Anger.
bump
11-29-2017, 10:01 PM | #20 |
Rep 1,351
Drives: in Anger.
Ok, pending sale this Friday. Uhggg.
11-30-2017, 03:54 PM | #21 |
1821
Rep 5,337
Congratulations, and condolences. Hope it's going to an enthusiast that will care for the car and DRIVE it.
12-01-2017, 07:04 AM | #22 | |
Rep 870
http://www.zpost.com/forums/showpost...postcount=2009 Congrats on the sale, Swashplate. Best of luck with your new ride. Salty
