      10-15-2014, 02:12 AM   #1
crash1
Drives: 2007 Z4 MC
front lower control arms
are there any good quality non oem option for front lower control arms replacement?
      10-15-2014, 04:03 PM   #2
Karacticus
Karacticus's Avatar
Drives: 2007 Z4 3.0si Coupe
I've got the Meyle ones on my car, as sourced through Bimmerworld.
http://store.bimmerworld.com/3-serie...arms-p236.aspx
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
      10-15-2014, 07:58 PM   #3
crash1
Drives: 2007 Z4 MC
they are the same price as factory part, are they better?
      10-15-2014, 09:49 PM   #4
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
99% sure M and 3.0 are different parts. Check realoem.com to confirm. Also check Turner for options.
      10-16-2014, 02:55 PM   #5
crash1
Drives: 2007 Z4 MC
yes they are different, the site karacticus suggested has the M version for $299 with is the same as OEM part. Is the aftermarket part better?
      10-22-2014, 11:52 PM   #6
E86Z
Drives: 3.0si
I've just replaced mine with OEM. The M and the 3.0 are infact different. You can fit ZHP arms according to turner but they're really expensive and require beefier bushings. Meyle HD has replacement ball joints which is convenient instead of replacing the whole arm when they fail
      10-28-2014, 05:25 PM   #7
crash1
Drives: 2007 Z4 MC
I opted for OEM also, mine was broken tho
