08-29-2014, 10:29 AM | #1 |
Rep 779
Brakes - What anti-squeal do you use ?
I ran out and didn't apply any when I change my rear brakes.. and yeah now when I tap the brakes a little I get the famous squeal noise.
What do you guys use on the pads ? should i get something like this http://www.ecstuning.com/BMW-E92-335...ads/ES2537721/
-Roranji
08-29-2014, 11:56 AM | #2 |
Rep 222
I've used this stuff with pretty good success, purchased through bavauto.com
http://noisefree.com/ It's not a fancy website!
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters |
08-30-2014, 05:35 AM | #3 | |
Rep 195
08-30-2014, 08:43 AM | #4 |
10843
Rep 4,892
For all the metal->metal contacts on the outside (like caliper->caliper carrier, back&sides of brake pads et) I use copper grease (very thinly applied), as I find that copper grease sticks better/leaves a better film in harsh conditions than silicone grease.
For the guiding pins I use a silicon based grease as it has rubber guiding grommets/bushings. I think plastilube is also a silicon based grease.
