      08-18-2011, 08:57 PM   #1
AirOpsMgr
AirOpsMgr's Avatar
Drives: 2006 Z4 3.0i
Dyno results: 06' 3.0i with manifold conversion
Hey all, thought I would post the results of the Dyno on my 06' 3.0i (N52 with 56750 miles) since I have recently swapped out the stock intake manifold with a 3 stage (si) intake manifold, thanks to the DIY -C- posted.
Setup: 3 stage manifold conversion, K&N High-flow drop in filter, charcoal air-box filter delete, 93 octane. Outside air temperature was 98 degrees, not sure what the humidity was, maybe 60-70%....
Best run was 191.0HP with 176.0 lbs of torque; The guy running the Dyno claims a 20% loss, so if 20% is indeed correct, this puts me at 229.2HP
1st run: 188.3 HP / 173.7 T
2nd run: 189.0 HP / 174.8 T
3rd run: 191.0 HP / 176.0 T
Link to the PDF graph below, or scroll down to the enlarged picture
2006 Z4 3.0i Dyno.pdf
Name:  2006 Z4 3.0i dyno.jpg
I plan to Dyno it again once I get the ECU tuning done ..... more to come!
Brgds/Greg
      08-18-2011, 10:00 PM   #2
CFoote
2022 M5CS  [0.00]
2001 BMW 740i  [0.00]
2006 BMW M Roadster  [0.00]
2012 BMW X6 3.5i  [0.00]
2006 BMW 325xi  [0.00]
2017 BMW 540xi  [0.00]
2000 BMW M5  [0.00]
2001 BMW X5 4.4i  [0.00]
Very nice -- now the other question is whether you could get the SI's software tuning put into your ECU? I think that was the other big item -C- (Chris) had mentioned. If you can have a tuner do that, I bet you'll make some big gains.
Overall though, very nice indeed!
Chris
      08-18-2011, 10:10 PM   #3
AirOpsMgr
AirOpsMgr's Avatar
Chris
Correct, that is exactly the plan; he is working closely with the tuning folks and we should know something very soon!!
