      03-21-2011, 10:28 AM   #1
Shipkiller
Shipkiller's Avatar
Drives: Me
Exhaust Can Removal Question
For those of you that have removed your exhaust cans/mufflers, did you have to replace the gaskets or were they able to be reused?
I know this is a general question and there will be variations....
      03-21-2011, 10:45 AM   #2
r4gs
Viper Driver
Singapore
36
Drives: F-16
by gaskets u mean the rubber stoppers/grommets? i reused the pair of white things u slot a bolt through to secure the frontmost portion of the mufflers. the four black rubber mounting grommets are fixed directly to the car, and as far as i can tell, permanently attached.
      03-21-2011, 11:28 AM   #3
-c-
-c-'s Avatar
Drives: bmw
he probably means the metal O gasket between the X-pipe and exhaust. it allows the muffelr to be ajusted. i think they can be reused.
      03-21-2011, 11:41 AM   #4
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
For cans, it's a flange metal "gasket" ring. Reusable.
Here's a really good DIY by crfine.
The rubber hangers are reusable too.
      03-21-2011, 12:14 PM   #5
Shipkiller
Shipkiller's Avatar
Drives: Me
-c- is correct.
It's item 4.
http://www.realoem.com/bmw/showparts...60&hg=18&fg=20
      03-21-2011, 03:32 PM   #6
r4gs
Viper Driver
Singapore
36
Drives: F-16
^sorry, i wasn't exactly sure what u were referring to by 'gaskets'. yes, i reused the circular rings in-between the x-pipe and mufflers
      03-21-2011, 03:58 PM   #7
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
+1 for re-use
      03-21-2011, 04:08 PM   #8
Shipkiller
Shipkiller's Avatar
Drives: Me
I just wanted to be sure, 90% of the time....
I called my local dealer and they want $19.00 each for them... Damn.
Tischer only wants $8.00 each..
Of course, AutoZone, Advance and Nappa do not carry them....
The reason for all this hubbub is that I am thinking of painting the bottoms black.
      03-21-2011, 04:11 PM   #9
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
It's a BMW - not a Sunbird/Cavalier...
2006 Z4MC - #LL93158
      03-21-2011, 04:39 PM   #10
Shipkiller
Shipkiller's Avatar
Drives: Me
I've owned both and they were both POS's...
You never know until you call....
      03-21-2011, 06:44 PM   #11
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
I've had mine disconnected twice, reused 'em both times. No leaks I can detect.... On this system, they act as a press form and the heavy clamp blocks will actually slightly deform the flanges on the x-pipe and cans to conform to the ring. This way, once the cans are hung and the clamps are looseley tightened you can raise or lower the tips to get things level and the clamps will still seal.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      03-22-2011, 11:16 AM   #12
Eccentric
Eccentric's Avatar
51
Drives: Interlagos Z4 M Coupe
You reuse them
WE ARE!!!!!!
