12-23-2016, 12:33 PM | #1 |
New Lifetime Replacement Policy
813
Rep 11,738
:: ECS Tuning:: WPC Treated Rod Bearings | Hold Oil Better
The two largest enemies of any high-performance engine are heat and friction - WPC has found a way to reduce both. WPC treatment is not a coating, it’s a metal improvement process utilizing high-speed micro peening technology giving higher compressive stresses creating a harder more durable finish which also creates oil retention pools which prevent oil starvation. WPC is a surface treatment that reduces friction and adds strength, two improvements that benefit your engine. What's better than using Original BMW rod bearings in your next engine build? WPC-treated OEM bearings! Click HERE for your E46 M3 WPC Treated Rod Bearings |
12-27-2016, 11:21 AM | #2 |
813
Rep 11,738
12-28-2016, 12:21 PM | #3 |
813
Rep 11,738
12-28-2016, 06:20 PM | #4 |
Rep 188
Hello on your website it mentions the following:
"WPC treatment is not a coating, it’s a metal improvement process utilizing high-speed micro peening technology giving higher compressive stresses creating a harder more durable finish which also creates oil retention pools which prevent oil starvation." Are there any data that can prove that and make me feel a little more secure that is a better solution that the OEM rod bearings? Thank you in advance. |
12-29-2016, 11:39 AM | #5 | |
813
Rep 11,738
-James |
inTgr8r2428.50 |
01-11-2017, 11:01 AM | #6 |
813
Rep 11,738
05-12-2017, 03:40 PM | #7 |
813
Rep 11,738
05-30-2017, 11:49 AM | #8 |
813
Rep 11,738
05-31-2017, 04:33 PM | #9 |
813
Rep 11,738
06-01-2017, 03:19 PM | #10 |
813
Rep 11,738
06-02-2017, 10:27 AM | #11 |
813
Rep 11,738
E30, E36, and E46 non-M drivers get excited! Now you too can take advantage of the amazing treatment that is WPC! Click HERE for your E30 318i/is Click HERE for your E30 325/e/es/i/is/ix Click HERE for your E36 318i/ic/is/ti Click HERE for your E36 320i Click HERE for your E36 323i/ic/is Click HERE for your E36 325i/ic/is Click HERE for your E36 328i/ic/is Click HERE for your E46 323i/Ci Click HERE for your E46 325i/Ci/ci Click HERE for your E46 328i/ci Click HERE for your E46 330i/Ci/xi |
