      06-13-2013, 11:40 AM   #45
v8z4
Drives: 2003 Z4 roadster
I started looking at the factory hood and the underlying brace structure would certainly be a pain to work around. CF is certainly the "easy" solution, it's just so dang expensive.
Chris
      06-13-2013, 02:02 PM   #46
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
How on earth is CF the "easy" solution ? A steel hood would have to be modified, built into a plug then molded b....THEN the process of engineering the lay-up schedule and tests for final product.
All I see is many weeks of hard work, trial and tribulations.
      06-13-2013, 02:13 PM   #47
v8z4
CF hood can be purchased with vents already in it (no modification necessary).
Chris
      06-13-2013, 02:16 PM   #48
Twisted Six
Drives: Z4si-coupe
None that I've seen properly built and executed. Vent placement was always in the wrong zones. But I see your point.
      06-13-2013, 02:18 PM   #49
v8z4
It shouldn't be "hard" to get one built with vents in the correct location, just expensive (more than my budget would ever allow).
Chris
      06-13-2013, 02:40 PM   #50
TSM330i
2006 330i, TSM, Black, manual, sport
TSM330i's Avatar
Drives: '17 C2, GTI, Z4 3.0si Racecar
Will do. I just grabbed the first thing I could find. Certainly need to do more research/planning before I'd ever consider cutting.
Here's a pic of an E86 Z4 GT3. You'll notice the hood vents are MUCH farther towards the front of the hood rather than near the cowl.
2017 Porsche C2 - manual of course
2015 GTI S
2008 BMW Z4 3.0si Coupe - because racecar
      06-13-2013, 02:47 PM   #51
v8z4
I don't know about everyone else, but to me all those vents (hood and fenders) look sick!
Chris
      06-13-2013, 04:20 PM   #52
Twisted Six
Drives: Z4si-coupe
When they are nearer the front , they are used specifically for the front grilles to cool the radiator etc.
When back near the windshield, more more manifold heat/engine bay heat.
      06-13-2013, 04:45 PM   #53
v8z4
My goal would be to increase radiator efficiency/let all the air that passes through the radiator out from under the hood.
Chris
      06-13-2013, 05:52 PM   #54
Twisted Six
Drives: Z4si-coupe
Sounds like you'll benefit from the front mounted vents like pictured then. Very effective .
      08-12-2015, 07:20 PM   #55
Sterling Roadster
Drives: e85 Z4 3.0i & e92 328i
I think if you could smooth out the edges on the louvers and blend it with the rest of the hood it would look perfect. I love the minimalistic design on the Z4 but on the M, I think this is totally fitting of it's personality.
      10-21-2015, 06:59 PM   #56
Steeler
Steeler's Avatar
2429
Attachment 1304732
FRP from scross the pond
      10-21-2015, 08:02 PM   #57
Sterling Roadster
Originally Posted by dbarton62 View Post
Attachment 1304732
This works for me, looks almost like something the concept would use. If I had an M, mine would being wearing this.
      10-21-2015, 09:20 PM   #58
v8z4
Attachment 1304732
Is that a fiberglass hood?
Chris
      10-22-2015, 05:17 AM   #59
Steeler
Steeler's Avatar
2429
Fibreglass reinforced plastic
      10-22-2015, 10:11 AM   #60
v8z4
Where did you get it? Is it lighter than the factory aluminum hood?
Chris
      10-22-2015, 11:10 AM   #61
Steeler
Steeler's Avatar
2429
No I don't have
It is from here
http://www.r-racing.co.uk/bmw-z4-e85...et-22869-p.asp
