03-10-2012, 08:53 PM | #1 |
Rep 416
RTAB
Well, I looked at my tires today and my rear right passenger shows wire on the inside. I looked it up and it appears that my RTAB are worn out. Anybody have any good recommendations for some? I was looking at rogue engineering.
03-11-2012, 01:40 AM | #3 |
Rep 514
Could be your alignment as well, too much toe. How many miles do you have?
2007 /// M Coupe Alpine White / Light Sepang Bronze 6MT
2003 /// M3 Alpine White / Imola Red SMG II (Sunroof Delete) SOLD |
03-11-2012, 10:31 AM | #4 |
Bad Lieutenant
232
Rep 3,517
Powerflex or OEM with Vorshlag shims
03-11-2012, 11:24 AM | #6 |
Car Geek
3612
Rep 3,579
03-13-2012, 10:43 AM | #8 |
Rep 1,660
Might ask on the Houston BMW CCA forum.
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
03-13-2012, 10:54 AM | #9 |
Rep 358
I had the same problem with my car at 21000 miles. I had the alignment checked, and everything was fine. Does anyone have a link for further info on RTABs (IDK even what they are) Thanks!
03-13-2012, 11:00 AM | #10 |
Rep 1,660
Rear Trailing Arm Bushings
03-13-2012, 06:27 PM | #11 | |
Rep 421
03-13-2012, 06:32 PM | #12 |
Rep 335
Drives: ae86; z4mc
03-14-2012, 10:33 AM | #14 |
Rep 335
Drives: ae86; z4mc
imho you may have rtab issues, but it looks like more camber wear than anything. rtab wear usually affect the tire as a whole because the actual bushing is flexing and causes the tire to "toe in" and "toe out" at excessive angels. This would show in the overall tire; and on some cars, even wear tires very rapidly. see below:
http://forum.e46fanatics.com/showthread.php?p=11250499 also note that his excessive wear came from the outside->inside. |
03-14-2012, 08:01 PM | #15 |
Rep 416
Good read, thanks! I was just planning on doing everything right the first time. RTAB replacement along with alignment and new tires. It would suck to do alignment to find out bushings are shot to changing bushings and then getting another alignment after bushings. Around $200 plus some elbow grease. Should be a fun learning experience
03-14-2012, 11:48 PM | #16 |
Rep 335
Drives: ae86; z4mc
yeah, sounds like a plan. probably get aftermarket (stronger) bushings along with the rtab limiters as well while your in there.
http://www.akgmotorsport.com/catalog...og.php?item=34 |
11-24-2013, 09:44 PM | #17 |
Rep 97
I would like to do this RTAB myself after watching a lot of E46 video posting on youtube.
However, there is the Z4M rear splash guard is in the way and no video on it. Can someone have good drawing / instruction on how to remove the rear splash guard without damaging it? Thanks |
11-25-2013, 05:18 AM | #18 | ||
Rep 2,138
Drives: Me
http://store.bimmerworld.com/powerfl...-rtab-p91.aspx Quote:
http://www.realoem.com/bmw/showparts...52&hg=51&fg=75 With the proper removal tool, it took approx. 45min a side to replace and install new RTAB's. |
11-05-2015, 08:21 AM | #19 |
Rep 1,107
For those who have installed limiters, I have read that with limiters installed the bushing will rotate under force when installed so there is no need to do the pre-load positioning of the bushing in the carrier. Does this sound correct?
Lastly, if someone could point me to the pre-loading instructions in the online TIS manual I'd greatly appreciate it (http://workshop-manuals.com/bmw/). I can never find things in there. |
11-05-2015, 09:19 AM | #20 |
Rep 11,667
With OE RTABs to set the preload, you jack up the trailing arm to the normal position as if the car was on the ground.
Then tighten everything up.
11-05-2015, 10:12 AM | #21 | |
Rep 1,107
I'm leaning towards one of these two methods: 1. Install but don't fully tighten bushing to carrier 2. Raise wheel assembly to ride height 3. Bolt carrier to car 4. Unbolt carrier and mark position of bushing to carrier 5. Jam something between carrier and RTA to maintain position of carrier relative to RTA while tightening center bolt to 81 ft/lb 6. Bolt carrier to car a. When lowering old bushing, mark position of carrier relative to RTA b. steps 5 and 6 as above |
11-05-2015, 10:35 AM | #22 |
Rep 11,667
It's been a while for me, I went with poly the last time (no preload)
With the RTAB up in position, can you not get to it with a spanner to tighten it, ( to hold position); Then lower it to torque?
