05-06-2010, 12:46 AM | #1 |
Rep 1,603
Drives: Imola Red Z4MC
Will this setup rub?
Sup guys,
gonna be buying a set of 19'' x 8.5'' et 30 wheels in the front and 19'' x 10 et 37 in the rear with a 15mm spacer (for the rears). Will the fronts fit perfectly with a 235/35/19 tyre? And will the rears fit perfectly with a 275/30/19?? Stock suspension (no lowering or nething)?? This is for the M Coupe btw Also, which set of tyres do you guys recommend between the Toyo T1R and the Falken FK452? Thanks a lot guys
///M - Some Mods 'N Stuff
05-06-2010, 01:53 AM | #2 |
Rep 698
I think you should be fine, You would probably get rubbage in back if you lowered it though.
I think the t1r's are better performance, the fk452 are more luxury/vip type tire, they also camber wear really well if it's on a car with heavy neg camber.
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
05-06-2010, 06:35 AM | #3 |
Rep 11,667
For comparison, on my previous M Roady lowered on H&R, I ran;
Fronts = 19x8.5 ET35 with 245/35 Rear = 19x9.5 ET22 with 275/30 Fronts I had some rub right where the wheel well plastic liner joins the front bumper. Since your setup will extend out an extra 5mm than mine, you will likely have the same rub. (even w/o a drop) You can fix this with a heat gun and push the liner back a bit. Rears, you will also extend 5mm more than mine. I had no problems at all, so chances are the extra 5mm will work w/o a drop. Note: Your camber settings will have a big impact on clearances. I had the front pins pulled & was somewhere around -1.6 I don't recall exact rear setting, but somewhere around -2.0
05-06-2010, 08:01 AM | #4 |
Rep 324
Works fine, exactly what I am running. No problem with rubbing unless lower.
2007 Black Sapphire Z4 //M Roadster, Hamann Front End, Hamann Rear Diffuser, Hamann 19 Inch Anniversary Wheels, Eisenmann Race Exhaust, Group M Intake, RPI Ram Air, CDV Delete
2006 E46 M3, 2004 Jeep Rubicon, 93 Golf VR6 |
05-06-2010, 08:33 AM | #5 | |
Rep 11,667
Checkout Hankook V12 http://www.caranddriver.com/reviews/...12_evo_page_10
05-07-2010, 02:22 AM | #6 |
Rep 1,603
Thanks for the input so far guys.....hankooks look interesting but still leaning more toward the falkens or the toyos!
