03-18-2015, 11:26 AM | #1 |
Gone but not forgotten
Rep 148
F/S 2009 335i Coupe Dinan S3-SOLD
2009 BMW 335i Coupe; 33,xxx miles; Titanium Silver exterior; Black Dakota Leather/Dark Burl Walnut interior; Premium Package; Sport Package; Steptronic auto transmission; Sport (multi-function) steering wheel w/ paddles; Moon roof; heated front seats; iPod/USB; Navigation; HD/Satellite radio; Bluetooth; Dynamic cruise control; tinted windows; Dinan Stage 3 Software Upgrade; Dinan CAI; Dinan High Capacity Oil Cooler; Dinan FMIC; BMW Performance Exhaust w/ Dimisa tips; M Power bushings in front; upgraded “is” rear bumper; M Aero front lip; M3 rear spoiler; 19” 313 Style BMW Performance wheels; upgraded LED angel eyes; tinted windows; spare tire kit; over $12K in upgrades; new Conti Extreme Contact DW tires on front at 25K; new Michelin Pilot Super Sport tires on rear at 30K; new battery 11/14; new plugs 9/14; enhanced “old school” maintenance; never raced or tracked; garaged at home and office; all records; original owner From Dinan website: Benefits of the Stage 3 Dinan Performance Software Upgrade: 98 More Horsepower / 129 More lb-ft of Torque: Stage 3 Performance Engine Software safely increases turbo-boost pressure and is optimized to take full advantage of the High Performance Intercooler. The boost is tapered at the higher levels to keep from overheating and damaging the turbos. With a peak horsepower of 398 at 5700 rpm and the peak torque of 429 lb-ft at 4300 rpm as tested with Dinan High Capacity Oil Cooler System and Dinan Free Flow Exhaust is a monumental increase over the stock 300 horsepower and 300 lb-ft of torque BMW quotes. Power: Being only 1 lb-ft and 14 hp short of a stock M3 in a package that costs less to buy, fill with gas and insure it is the perfect weekday commuter and weekend canyon carver. Drivability: There is more to a tune than just cranking up the boost. Power needs to come on smoothly and in a predictable way to make the car as fun to drive at wide open throttle as cruising around town. It is your BMW, but reborn with new found acceleration and speed. Top Speed Governor Removed: Dinan’s software removes the top speed governor so your BMW will be capable of achieving its true natural top speed. A True Software Tune: The biggest difference between a true software tune like Dinan's Performance Software and a "piggyback box" is that all of the communications between the engine sensors and the engine management computer (DME) remain unaltered. This translates to properly returned fuel mixtures, Ignition timing and full map rescaling to keep everything in sync. Keeping an engine running at its best and with the most reliable power is what Dinan is all about. Well Engineered: Properly returned fuel mixtures to the DME along with a correct tune means keeping the engine running cooler with less wasted fuel. Ignition timing is a critical part of the equation to limit engine knock, one that many tuning companies ignore, Dinan Performance Software includes full map rescaling to protect the engine and keep everything running smoothly. All BMW Engine Safeguards Retained: BMW worked hard to build systems to protect the engine incase of a failure, Dinan keeps all of these systems in place for the safest possible tune. Remapped Water Pump Speeds To Control Engine Temperatures: The N54 engine is known to run a little warm in stock form. In an effort to more effectively control oil and water temperatures, the Dinan software actually increases water pump speeds as boost pressure increases. Easy To Use: Add modifications and use different levels of octane without worry because the ECU will adapt to the changes, automatically leaving you to just enjoy your Dinan tuned BMW.; Gas Mileage: This is the beauty of a turbo engine. When the engine is not in boost (below about 3K rpm) it is sipping gas like a small non-turbo engine would. It is only in boost that extra fuel is burned and with the Dinan software more is burned at the higher boost levels. It all depends on your right foot, if you drive it gently it will use the same or slightly more gas and if you drive it at wide open it will use more.
2015 Audi SQ5
RECENT PAST 2013 Porsche Boxster S 2009 335i/Coupe/Dinan S3 2006 BMW Z4 3.0si Last edited by Lark; 04-24-2015 at 02:12 PM.. Reason: Sold |
