      04-09-2013, 10:35 PM   #1
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Which ARC-8 fronts can I run?
Hey guys,
I'm very close to pulling the trigger on a new set of 18" ARC-8s... I love the concave look!
I am however, having a hard time deciding which front wheels to buy... My current set up is very simple; I am just lowered on H&R springs with no camber plates or anything.
My question for you wheel gurus out there, is can I run the more aggressive front wheels like the fellow in this picture without having to purchase $400 camber plates? My tire sizes will be 235/40/18 and 265/35/18.
Please help!
SOLD: 2008 M Coupe
      04-09-2013, 10:39 PM   #2
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Short answer - No.
Without running more camber, you cannot run a wider wheel. It is common to use 18x9.5 and go 255 or 265 squared ET35 so you can rotate front/rear (you'll need around a 12mm spacer in the back with ET35)
You can use camber shims though...you'll need 2.6-2.7*+ to clear the front strut with the addition of a 5mm spacer.
      04-09-2013, 10:43 PM   #3
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Are you talking about adding positive or negative camber? Sorry man, I'm a complete n00b when it comes to this stuff.
SOLD: 2008 M Coupe
      04-09-2013, 11:49 PM   #4
Kgolf31
Kgolf31's Avatar
460
Negative camber...OEM runs around -0.5 to -1*
Pulling the alignment pins on the top of the strut hat in the engine bay can get you around -1.5*
If you're running positive camber something is seriously jacked with your suspension
      04-10-2013, 12:06 AM   #5
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Ok cool, thanks for the info. Are the camber shims "safe" (i.e., durable) to use with stock suspension?
SOLD: 2008 M Coupe
      04-10-2013, 09:42 AM   #6
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Also, has anyone run a 235 width front tire on a 9.5" ARC-8? I reeeeeally want to run concave fronts and backs, but I'm not sure if my front tires are too narrow for it?
SOLD: 2008 M Coupe
      04-15-2013, 08:55 AM   #7
Platinum Child
Platinum Child's Avatar
128
Drives: Tiag z4mc
I'm running 18x9.5 et22 up front with a 245/40 and stock camber. It sticks out a tiny bit, needs about -2.5 camber to be flush like the rear.
      04-15-2013, 10:12 AM   #8
Shorts
Drives: E86 M coupe, E91 325xi
Can you please post a pic of this? It would be greatly appreciated.
      04-15-2013, 10:27 AM   #9
Kgolf31
Kgolf31's Avatar
460
I run shims and I'm perfectly fine.
For the 235s, you might be stretching the tire a bit on a 9.5" wheel.
      04-15-2013, 09:22 PM   #10
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Stock height too then im guessing?
SOLD: 2008 M Coupe
      04-18-2013, 10:53 AM   #11
Platinum Child
128
Drives: Tiag z4mc
Yeah stock height, if the car was lowered they would tuck in more. Will have a pic soon
      04-18-2013, 04:11 PM   #12
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
K that explains it. If you were lowered, you would need camber plates and a bunch of neg camber to run a 22 offset up front on a 9.5" wheel. Thanks for the input!
SOLD: 2008 M Coupe
      04-18-2013, 06:31 PM   #13
Platinum Child
128
Drives: Tiag z4mc
Should have my coilovers in 2 weeks, will be setting front camber at about -3 or -3.5 for the track. Should it flush with 265/35/18 up front and 285/35/18 out back
