11-22-2009, 02:54 PM | #2 |
PCA, BMWCCA
102
Rep 2,058
How much do YOU weigh? And whatever pounds you lose in the seats you'll never be able to detect a performance gain so why bother???
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU |
11-22-2009, 03:35 PM | #4 |
Rep 1,090
I think someone said the stock electric m seats weigh around 50lbs?
Swapping to some Recaros or similar would save a good deal of weight. Probably one of the best weight savings we can do. Then if thats too much work a lightweight batt and lighter wheels/tires would also cut down a fair bit.
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
11-22-2009, 05:54 PM | #6 |
PCA, BMWCCA
102
Rep 2,058
I'm glad you're sticking with the same seat. Racing seats are great for the minimal time you need them. Getting in and out of them is no fun whatsoever, even if very trim like me. I love my seats, and appreciate the power option for the perfect adjustment.
11-23-2009, 05:56 AM | #8 |
Rep 821
A good way to see if weight reduction is going to be more than just 'locker room' talk is to go to the track, road or drag, which ever you do. Make a couple of runs at stock weight. Then put a 10 lb bag of something in our car and make a couple of runs again. Compare times. Put a 20 lb bag of weight in your car and make a couple of runs, compare times. The time you loose by adding the weight should give you an idea of the time you might gain by reducing your stock weight the same number of pounds. Good luck.
11-23-2009, 08:20 AM | #9 |
Rep 4,057
I've never raced so this may be a totally stupid suggestion; I apologize if it is.
How about if you run with the gas tank only filed with what gas you need for each run? I assume gas weighs about the same as water, which is 1 kilogram per litre, or almost 9 pounds per gallon. So for example, I think the car has about a 50 litre tank. If you only half fill it, you drop the car's weight by 25 kg or 55 pounds. Only quarter filling it takes that to about an 80 pound weight reduction. Again, sorry if this is already common practice. Huzz |
11-24-2009, 05:12 AM | #10 | |
Rep 821
