      05-15-2012, 10:02 PM   #1
MFGJR
Drives: 2007 Z4 M Coupe
Just wanted to let folks know that the VAC Motorsports E36/46 under-seat fire extinguisher mount works on either the driver or passenger side in a Z4.
The mount is fixed in position (it doesn't move with the seat) and so with the extinguisher installed you do lose a small amount of forward seat travel, at least with sport seats. I'm 5'11" but have short legs and sit pretty far forward compared to most; I still have two-three inches of forward travel, so shouldn't be a problem for many. Also, not compatible with the first aid box.
Install is easy--remove the nuts holding the seat tracks to the floor in front, loosen the rears, lift the front of the seat and slip the mount over the studs between the carpet and the tracks, and tighten everything up.
I have a 2.5 lb Halotron extinguisher with metal valve and hardware in mine. Warning--it can be hard to find these extinguishers. I tried numerous sources, and all were chronically out of stock. Finally lucked out after a couple months and caught CDOC with one in stock.
I don't really anticipate using the extinguisher during an on-track incident. Rather, it's comforting to have one readily at hand in the paddock or on the street.
http://store.vacmotorsports.com/vac-...e46-p2023.aspx
http://store.cdoc.com/h3r25lbpremium...inguisher.aspx
      05-16-2012, 12:12 PM   #2
Z4MLover2012
Drives: 2008 Space Gray Z4M Coupe
Nice setup!
      08-28-2012, 03:48 PM   #3
3002 tii
3002 tii's Avatar
2282
bump... can anyone school me on the different type of extinguishers? thinking of running with pca's advance group soon but some of the chapters require fire extinguishers and the oem kit is not compatible. they suggest a 2.5lb halon or something "similar"... not sure what constitutes as similar. what should i be looking for when choosing one for DE purposes?
this one is $50
http://www.ogracing.com/sodium-dry-p...guisher-2-5-lb
and this one is $120
http://www.ogracing.com/halotron-fir...guisher-2-5-lb
Follow for latest mods
      08-28-2012, 08:13 PM   #4
SD ///M4
///Multiple
SD ///M4's Avatar
Halon has been banned since 1994 and Halotron is the approved, non-ozone-depleting, non-human-toxicity replacement (Wikipedia, bold and italics mine):
Clean agents and carbon dioxide
The agent displaces oxygen (CO2 or inert gases), removes heat from the combustion zone (Halotron, FE-36) or inhibits chemical chain reaction (Halons). They are labelled clean agents because they do not leave any residue after discharge which is ideal for sensitive electronics and documents.
Halon (including Halon 1211 and Halon 1301), a gaseous agent that inhibits the chemical reaction of the fire. Classes B:C for lower weight fire extinguishers (2.3 kg; under 9 lbs) and A:B:C for heavier weights (4.1–7.7 kg; 9–17 lbs). Banned from new production, except for military use, as of January 1, 1994 as its properties contribute to ozone depletion and long atmospheric lifetime, usually 400 years. Halon was completely banned in Europe resulting in stockpiles being sent to the United States for reuse. Although production has been banned, the reuse is still permitted. Halon 1301 and 1211 are being replaced with new halocarbon agents which have no ozone depletion properties and low atmospheric lifetimes, but are less effective.
Halocarbon replacements, HCFC Blend B (Halotron I, American Pacific Corporation), HFC-227ea (FM-200, Great Lakes Chemicals Corporation), and HFC-236fa (FE-36, DuPont), have been approved by the FAA for use in aircraft cabins in 2010.[13] Considerations for halon replacement include human toxicity when used in confined spaces, ozone depleting potential, and greenhouse warming potential. The three recommended agents meet minimum performance standards, but uptake has been slow because of disadvantages. Specifically, they require two to three times the concentration to extinguish a fire compared with Halon 1211.[14] They are heavier than halon, require a larger bottle because they are less effective, and have greenhouse gas potential.[15] Research continues to find better alternatives.
The extinguisher in your second link is the Halotron variety and will be much less messy and more suitable for an engine/cabin fire than the dry powder sodium bicarbonate extinguisher in your first link.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
      11-24-2014, 06:35 PM   #5
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
After a couple of years with this mount, how do you like it?
      12-08-2014, 07:49 PM   #6
MFGJR
Well, sold the car over a year ago... so, rarely on this board anymore. Extinguisher was a little bit in the way getting in and out of the car, but just a very minor annoyance. Mount held the extinguisher very securely, so no problems there.
