      11-22-2014, 07:22 PM   #1
Barryb97
Drives: 2006 M coupe
z4 M differential fluid
Looking to change the fluid in my differential. I'm finding it difficult to find the SAF-XJ without the Friction Modifier (83221467993). I've seen some posts saying that the Castrol Syntrax 75W-140 is equivalent. Has anyone used this or found any other substitute?
      11-22-2014, 08:58 PM   #2
8nthatk
Drives: 2006 Z4 M
What I use…
http://www.amazon.com/GT-R-NISSAN-DI...ords=gtr+fluid
      11-22-2014, 09:20 PM   #3
itdnwiwbp
Drives: 330iZHP
I have some Redline on deck for my next change. I'm not home some I don't have the spec in front of me but I got what Mike Miller recommends for Ms.
      11-23-2014, 12:19 AM   #4
Valhalla1*
Drives: '07 Z4 3.0si Coupe
Are you referring to Mickey Miller at Bullet Performance?
      11-23-2014, 06:53 AM   #5
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I changed to Liqui Moly 75w-140 about 20k miles. No problem or any noise from diff.
http://www.liqui-moly.de/liquimoly/p...d/en_4421.html
      11-23-2014, 09:15 AM   #6
itdnwiwbp
Drives: 330iZHP
Mike Miller of BMWCCA Tech Talk.
      11-23-2014, 12:30 PM   #7
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Redline can be had without the FM within it, it can be sold separately and added if you encounter chatter. I never use the BMW FM stuff, it defeats the diff's purpose IMO.
      11-23-2014, 12:55 PM   #8
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Motul on deck...
http://www.turnermotorsport.com/p-24...d-1-liter.aspx
2006 Z4MC - #LL93158
      11-23-2014, 12:57 PM   #9
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Please expand on the use of FM and the operation of the Diff. Thanks in advance.
      11-23-2014, 03:20 PM   #10
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
The friction modifier reduces friction to alleviate the "noise". Groaning, is normal, chatter is not. If you use the friction modifier, the diff will lock less, thereby reducing its effectiveness.
All my BMW diffs have groaned in the cold.
It's funny we see these posts most often when winter approaches or sets in
      11-23-2014, 05:15 PM   #11
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Thanks.
