      02-15-2017, 04:20 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
Options: Z4 nonM rear bumper modifications
Looking to add some more aggressiveness to the nonM z4 rear bumper (revised bumper). Any options out there? Found some diffusers which sit underneath, but not my style.
Was looking for something like this:
But no longer made...
Or this:
But obviously for the E85/E86 version - nothing exists.
Not looking to replace the bumper either. Thoughts?
      02-25-2017, 06:04 PM   #2
dre99gsx
Screw it... found a way to adapt the E89 Z4 carbon fiber diffuser onto my 3.0si
Took a bit of elbow grease, but it fits
      02-25-2017, 06:08 PM   #3
GuidoK
#buildnotbought
GuidoK's Avatar
10834
Drives: Z4 3.0i ESS TS2+
Very nice!
Do you have pictures of your dual exhaust setup? There arent any in your build topic.
Curious if you went Y pipe from the mid of the car (so true dual muffler) or a breakout pipe to the right from the rear muffler.
      02-25-2017, 06:39 PM   #4
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
Originally Posted by GuidoK View Post
Very nice!
I second this question. Guess this would fit on a 03 roadster too? Turned out great my friend.
      02-25-2017, 07:13 PM   #5
dre99gsx
Thanks. The diffuser follows the rear bumper curvature, but mounting it required some trick brackets hidden inside. I cut the bumper in minimal locations as well, didn't need much trimming.
As for the exhaust, I run a single muffler to the driver-side dual tips, and the external wastegate via a long tube to the driver side pipes.
No pics on the build thread since this was an afterthought I'll have better pics sometime next week.
      02-25-2017, 07:45 PM   #6
GuidoK
#buildnotbought
GuidoK's Avatar
10834
Wastegate as seperate exhaust tip. Thats pretty original I must say.
      02-26-2017, 07:03 AM   #7
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
That looks GREAT!!! Excellent job
Powered by
      02-26-2017, 02:46 PM   #8
dre99gsx
      02-26-2017, 03:23 PM   #9
E86Z
Drives: 3.0si
This is great news, looks good too gj
Did you have to move the exhausts to fit the diffuser or did they happen to line up?
      02-26-2017, 03:28 PM   #10
dre99gsx
Thanks! Had to shift the driver side muffler over about 2 inches further to the edge. This is because the stock E89 Z4 exhaust holes are further spaced apart.
      02-26-2017, 03:36 PM   #11
dre99gsx
      03-02-2017, 03:28 AM   #12
Hammam
BMW Freak
Germany
53
Drives: Z4M Coupe + E36 & F11 Touring
in the german zroadster forum there is a guy you has made a near-oem replica of the E86 Facelift aero carbon diffusor.
      03-03-2017, 04:09 AM   #13
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Pics?
      05-30-2017, 07:35 PM   #14
JVDHM
JVDHM's Avatar
Drives: 3.0si Coupe
There is always the Rieger diffuser for anyone else looking
