      02-10-2008, 06:54 AM   #1
Papsy
ZZZZ
Drives: Z4 2.0i
Type of TPMS on Z4
What type of TPMS is used on a Z4?
Is it a sensor based system, which requires a sensor attached to each wheel (valve)?
Or is it an ABS based system, which uses the ABS of the vehicle to monitor the rotation speed of the individual wheels?
      02-10-2008, 07:29 AM   #2
epbrown
epbrown's Avatar
From 2003 to 2006, an ABS system. From 2007+ they use wheel-based sensors.
      02-10-2008, 08:44 AM   #3
Papsy
ZZZZ
Drives: Z4 2.0i
Thx, that's easy for mounting a new set of wheels. I'm looking at mounting 18" CSLs in the spring.
      02-11-2008, 12:16 AM   #4
Zeddy4Me
Zeddy4Me's Avatar
South Korea
24
Drives: 09, AW E90 M3 6MT
It cost me $200 for a new set on my new wheels...
      02-27-2008, 10:28 AM   #5
Hawkeye
Hawkeye's Avatar
No_Country
2070
Zeddy, you said you got the TPMS from EAS right?
Do they come in the mounted tires or is that something you have the have the shop install as well as the tire? Is there anything else (electronically) that needs to be configured or reset when doing this?
I am also looking at 19" CSL Reps in the spring.
      03-02-2008, 04:20 PM   #6
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
Hawkeye: Only thing I know of is, whenever you mess with the TPMS, add air, remove air, etc. You need to reset the TPMS sensors by pressing and holding the button until the light turns on, drive the car for a few feet and it will store the new "base measurements"
