      09-10-2009, 07:25 AM   #1
alekos911
alekos911's Avatar
Greece
Drives: z4 coupe 3.0si-996 carrera 4s
UUC recommends a compination of two lubricants for our gearboxes
:http://www.uucmotorwerks.com/html_te...nny_rattle.htm
Have anybody tried this?
Does anybody know this UUC motorwerks company? Is it credible enough to publish such instructions?(note that I don't live in the States)
What do you think? From What I've heard Redline ATF D4 (something like that) is the recommended oil type for manual transmissions. What do you all believe? Is it worth trying this weird combination?
Thank God for creating MAN to create THIS CAR
(ps: I am trying to improve my fluency in English, so feel free to correct me when it's neccessary)
      09-10-2009, 07:34 AM   #2
JCz04Bimmer
JCz04Bimmer's Avatar
32
Drives: 06 Z4MC
VERY reputable company. Rob Levinson, the owner, is a very active contributor to the BMW community and they make top notch parts. You can definitely feel comfortable following their counsel on pretty much any topic related to BMWs!
|www.onehotlap.com|Real People|Real Cars|
      09-10-2009, 07:57 AM   #3
alekos911
alekos911's Avatar
Greece
So would you try this? Or should I go only with the ATF D4?
      09-10-2009, 08:31 AM   #4
jonanator
Drives: '08 E93 335i, '06 Z4MC
This is recommended for the stock tranny, right? My car is an '06 and it definitely wouldn't hurt to flush and replace the transmission fluid to get it smoother.
      09-10-2009, 10:17 AM   #5
O-cha
O-cha's Avatar
218
Drives: Mcoupe
:facepalm:
What he is describing is for cars with lightweight flywheels to try and get rid of the chatter. They aren't recommending it for stock cars. All it is is a mixture of fluids to allow low temperature protection, but that is still thick enough to dampen the noise.
      09-10-2009, 10:32 AM   #6
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
Yes UUC is a credible source for most info. But like O-cha said, this is for cars running a lightweight flywheel only. If yours is stock, stick with 1 fluid type.
      09-10-2009, 03:25 PM   #7
alekos911
alekos911's Avatar
Greece
My Z has the OEM flywheel. So I will try 1 fluid type. But I don't know which one.The ATF D4 or MTL(manual gearbox). I think both are proper for use
