      10-28-2007, 02:32 PM   #1
kav
Drives: Z4M
Z4M wheel fittment
I am looking to use some M3 wheels on my Z4 M coupe for the winter but I have been having trouble finding out some information on the rims to verify their fittment..
The rims I am considering buying are used and are the ones listed on this link. Could anyone please post information on these wheels, size, bolt, width, etc..
LINK>
http://www.canadiandriver.com/articles/hl/04330xi.htm
Thanks
      10-29-2007, 02:07 AM   #2
chaforjohn
Drives: 2006 Black M Coupe
e46 m3 fitment will fit fine on our cars.
      10-29-2007, 05:34 AM   #3
kav
Drives: Z4M
Thank you for the response.. Do I need any spacer, etc?
      10-29-2007, 08:41 PM   #4
kav
Drives: Z4M
Anybody??
      10-30-2007, 12:03 AM   #5
unionjack
Conceited Prick
unionjack's Avatar
14
Drives: Z4 M Coupe previously
2007 Z4 M Coupe  [0.00]
no
previously
AW/IR | Premium Package | Heated Seats | Navigation | Valentine One | Shorty Antenna | Black Kidney Surrounds
      10-30-2007, 09:22 AM   #6
kav
Drives: Z4M
Originally Posted by unionjack View Post
no
No I don't need any spacer?
Thanks you.
      10-31-2007, 09:44 AM   #7
unionjack
Conceited Prick
unionjack's Avatar
14
Thanks you.
No, no spacer required.
previously
      10-31-2007, 07:00 PM   #8
The HACK
The HACK's Avatar
1821
If you're buying wheels design specifically for the E46 M3 then they'll fit. However, the wheel in the link you provided were for a regular E46 3 series. While TECHNICALLY they fit, the offset is incorrect and if I'm not mistaken, the rear wheels will be tucked in further by ~17mm. Not an ideal situation. Also, if those wheels already comes with tires they'll likely be the wrong aspect ratio as well for the MZ4.
You will need to run the right aspect ratio, which should be 225/50/17 or 245/45/17 winter tires. Ideally you will also need a 15mm spacer to bring the offset into compliance with an MZ4 offset. The rear offset on those rims, if they're not designed to be used by the M3, will be ~17mm too small. The MZ4 rear offset for a 9" wide rim in the rear is -30mm, while typical E46 none-M rear offset on a 8.5"-9" wide rim is -44 to -47mm. E46 M3 rear offset on 9" wide rim is 26mm so you're close enough there.
      11-11-2007, 09:42 PM   #9
Ron@Modbargains
Ron@Modbargains's Avatar
Drives: 996TT/ae86
Using the M3 fitment is good on the M Coupe - if anything you can go slightly wider on the rear of the Mcoupe then the M3's so some people may want to take advantage of that by putting even wider rear tires.
      11-13-2007, 11:20 AM   #10
VoiD
Drives: Z4MC >>> C63
Can I fit 19x10.5 +25mm in the rear with 275/30 tires?
      11-13-2007, 08:44 PM   #11
Evoking
Drives: Z4M Coupe
If the MZ4 can run e46 fitment then why does it seem we have fewer options for Z4m than for M3?
I'm looking to buy some wheels as well. The question I have is whether there is any substance to this... If I take some 19x10 rear iForged or SSR's off an M3 will it work on my car?
