02-08-2016, 09:20 PM | #617 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Brake Pad Thickness Gauge
Bought a BMW brake thickness gauge (used). Handy tool for measuring brake pad thickness without removing the wheel.
Here is how it is used: http://www.bimmerfest.com/forums/sho...1&postcount=91 Salty
02-14-2016, 11:54 AM | #618 |
dances with roads
4722
Rep 4,096
I just pulled the trigger on a pair of M Sport seats on eBay. Black leather with power and heat. They came from a car with a build date within 6 months of my car, same make/model, driven about 10K miles further. They show some wear but not much (from what I can tell in the picture anyway). I'll have a chance to take them somewhere for cleaning up and refurbishing as needed. The donor car fired its airbags so the seatbelt latch/tensioners are no good; but according to realoem.com there is only one part number that fits them all so I'm hoping to be able to swap them over from my current seats.
Fingers crossed that the condition is decent, that everything works, and that I can swap in my bits. If so I'll be a happy puppy indeed! The only regret I have leftover from not buying the first Z4C I looked at was that it had sport seats. (They smelled like cigarettes so the regret is minor.) The only option my current car doesn't have that I wish it did have is, you guessed it. Last edited by wdb; 02-14-2016 at 12:02 PM.. |
02-15-2016, 04:46 AM | #619 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
Thinking about swapping out the e-brake to better match the new shift knob, and aluminum dash....just have to confirm fitment
02-15-2016, 08:17 AM | #620 |
Rep 12
What did you buy for your Z4
Getting ready for Spring!
transmission filter and fluid Castrol Edge oil and filter Air filter cabin filter mobility kit for tires Carly for BMW (to do some minor coding) New Spark Plugs Now waiting for warm weather to put it all in....Come on Spring! |
02-15-2016, 11:08 AM | #621 | |
Rep 4,057
Thanks for the tip!!
Huz-Z
02-15-2016, 06:33 PM | #622 | ||
Rep 1,689
You will like them as they also brighten the up per dash. You will like them. |
02-21-2016, 02:43 PM | #624 |
Rep 2,704
Adder to post 593
The app will not let me post more than one pic via iPad.
So here is the front brake set up as part of the kit noted in post 593 Retaining clips were missing in the box so the manufacturer is shipping ASAP
02-21-2016, 03:08 PM | #625 |
Rep 12,565
Wait is there more to this, i.e. rear muffler delete or did you just replace the secondaries with a muffler (which would lead me to think it's now quieter).
02-21-2016, 03:28 PM | #626 | |
Rep 1,689
I am going to ditch the OEM exhaust which was plan B from the start if the sound profile was satisfactory, but since it was more quiet after I removed the secondary cats and X-pipe I will have straight pipes with 3" tips. The plan was to have the secondary cats removed and replace with the Magnaflow exhaust to take the place of the secondary cats as a resonator. And the OEM X-pipe was removed due to space constraints as well. So far I have not been back the exhaust shop to have "plan B" implemented yet. Some have had success with just removing the secondary cats and I was one of the few that did not. So I will update once I have it done. |
02-21-2016, 08:10 PM | #627 |
Down Under!!
1621
Rep 4,294
Bought some mint KW Clubsports with camber plates from forum member AriuSen, Should be shipping any day now.. cant wait to get them
Powered by |
02-21-2016, 10:55 PM | #629 |
636
Rep 3,124
BimmerWorld motor mounts, a Z3 motor mount heat shield, and Thermo-Tec Kevlar Heat Barrier to build a heat proof skirt around the right side mount.
02-22-2016, 07:29 AM | #630 | |
Rep 12,565
Be sure to update us. If I were you I'd keep what you've done so far, merge the pipes and run a 3" mandrel stainless exhaust. PM if you need need help with parts. |
02-26-2016, 06:43 AM | #631 |
Rep 274
MStach2 from Steve, thanks Steve!
Because my coupe is Carbon Schwarz I had it painted the same color then fitted it up myself. I took a pic of it in the sun so the blue comes out. Also leatheriqued the seats and wheel- that stuff works! Beautiful matte finish restored to the leather. |
02-26-2016, 07:36 AM | #632 | |
Rep 870
Salty
02-26-2016, 09:39 AM | #634 |
Down Under!!
1621
Rep 4,294
yeah mate, looks bloody great quality piece by Steve show us the seats Digs
Powered by |
02-26-2016, 01:48 PM | #635 |
Not a New Member
94
Rep 925
this needs its own thread! more pics please!!!
02-26-2016, 02:24 PM | #636 |
Rep 11,667
^whs
02-26-2016, 11:55 PM | #638 |
Rep 439
Well, it's not completely in the last week, but...
- Had a small front end collision a bit ago that resulted in getting a brand new front bumper, oil cooler, left headlight assembly, and other random front end parts. Took 7 weeks for the body shop to finish the repairs, and had some subsequent issues that followed. Was kind of a nightmare. - When I picked the car up from the body shop, the car had magically developed a VANOS failure due to broken exhaust hub tabs, so the hub got replaced. Took an additional 5 weeks for this to get diagnosed and fixed. (This is 11 total weeks that my Moupe was in the shop, for the kiddos counting at home. During which time I spent half the time in a rental Sante Fe, and the other half in a rental Chevy Sonic. Talk bout hell...) - PKM module for the fuel pump also apparently went bad (probably due to the dumbasses at the body shop running the car out of fuel while testing after installing the new oil cooler) - New starter, as the old one was beginning to go bad - New front reflectors (as the dumbasses at the body shop apparently broke a few of the tabs holding the connecting ring to the actual reflectors.) Noticing a pattern here? I'm actually in the middle of clear-coating the new reflectors after painting them body color - Carbon fiber license plate frame - New Mstache V2 to replace the old one that was destroyed in the collision. Currently it is sitting in my living room, sanded, waiting for me to decide if I want to paint it piano black, matte black, or get it hydro-dipped with a CF pattern. - Got the replacement set of headers from Status Gruppe Tuning to replace the slightly messed up set they sent me when I first ordered them. Should be installed in the next couple of weeks. So yeah, a lot of stuff, haha.
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS |
